Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother MFC 465CN Printer, NO YELLOW
Suddenly there is no yellow. Put in new ink cartrige, cleaned, same. Replaced all ink cartridges,cleaned, no help. Black Cyan and Blue work fine. Took it to a local repair shop, said it wasn't worth fixing and tried to sell me a new printer. Really like this combo printer and wondering if there is an at home test or fix that you might suggest.
  • 4,041 Answers
Hi There
A good old clean out some times works do this 2 or 3 times.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
Yellow is not appearing in my color printings
Often, when a color is not printing, or it is not showing the correct shade/color, it is because one or more of the color ink cartridges is low or empty. See if this happens when you use new ink cartridge(s)
Mar 03, 2014 | Brother MFC-465CN InkJet Printer
I just installed new ink in my Brother MFC-465CN and the black will not print.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 16, 2010 | Brother MFC-465CN InkJet Printer
I have the Brother MFC-685CW Fax Printer, I replaced the Yellow ink cartridge but it still comes up with message "Yellow No Ink" What can I do?
Hi there
You can try.
Just take them out and gave the brass connexions a good clean and put back.
All the best Pineworks
Apr 27, 2010 | Brother MFC-685cw InkJet Printer
Brother MFC-640CW All-In-One yellow not printing
if your print head is removable (the thing your ink cartridge clips into) remove it and clean it out with asorbic alcohol on both the print face and the ink inlet area- If your yellow has been empty for a while before you bought a new cartridge, it is possible that ink has dried in the ink channels of the print head and this is almost impossible to repair and you would be better off buying a new print head- Also if you have a fairly new printer you can contact the manufacturer about your issue and they may or may not send you one for free- My KodaK AIO had the same issue and Kodak replaced the print head for free all I had to do was take the time to call them
Apr 07, 2010 | Brother MFC-640CW All-In-One InkJet...
My printer say no cartrige for C M and Y at the same time and when i change the cartrige it says the same
all brother printer has no chips on the cartridge, they are all detecting through sensor,you can find it on the ink cartridge area.
Sep 04, 2009 | Brother MFC-465CN InkJet Printer
Change ink
buy a new cartridge, open the front the door, pull the small handle, the cartridge will come out, and insert the new one. there might be a piece of tape on the cartridge that you have to take off first.
thanks
May 25, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Yellow color does not show
put new original cartridge and off the printer. Turn on after 2-3 days. If printhead clogging,original inks can unclogg....
Oct 18, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother 210c says ink needs to be reinstalled
i have just bought new cartridges and it asks have you replaced yellow, i say yes it says no cartridge, any ideas?
Sep 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
693 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
