Question about Dishwashers
Diplomat dishwaser fault
I have a Diplomat dishwasher ADP8322,when the unit is switched on and it starts to go through the cycle, after a short time five or so mins.
The fault light comes on and the dishwasher then continually bleeps showing a fault.
I have replaced the circulation pump as this was shorted out.
The unit does let in water and heats up.
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: Diplomat ADP8322 problem
I had the same problem. its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
Hope this helps
Posted on May 07, 2008
douglas smith
  • 1462 Answers
SOURCE: Got a Diplomat ADP8322. Starts
possibly heating element - only way to find out is to check continuity with a multimeter.
there is also a thermal cutout in series with the heater which could also have gone
Posted on Jun 24, 2008
Anonymous
  • 639 Answers
SOURCE: diplomat adp8322 dishwasher soap dispenser
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Anonymous
  • 103 Answers
SOURCE: I have a Diplomat Dishwasher which goes through
get model number on machine, post it here so we know which machine it is or search internet for "diplomat error codes", enter your model number and error code and it will tell you what it is. Each machine has different error codes.
Posted on Oct 09, 2009
sathyin23
  • 70 Answers
SOURCE: Hi I have a diplomat dishwasher adp8322. When I
problem with your board(or)pump.
Posted on Jan 07, 2010
Dishwaser won't start
Check the door interlock switch. They normally run the L1 line through the door switch and if the door switch shorted, the dishwasher appears dead. Good Luck, Eric Campion
Mar 24, 2012 | Dishwashers
Diplomat adp8322 dishwasher has start button flashing 7 times and rinsne cycle light on what does this mean
This is stating that no water is entering the dishwasher.
My solution was to turn the power off at the wall and wait for 10 minutes.
Turned it back on. Pressed the Start button and held til it beeped and reset, then started as normal and all was fine.
Jan 02, 2010 | Dishwashers
Water not draining in the bottom of the dishwaser,no power at all
if you have a row of buttons on the left side for heat cycles check them a shorted switch will cause a loss of current situation so that the drain solnoid wont activate
Oct 12, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Got a Diplomat ADP8322. Starts Cycle then starts bleeping 3 flashes which is a heating error. No hot water at all. Had a look and cleaned watr pressure switch still not working. Any ideas has the heating...
Jun 24, 2008 | Dishwashers
Wirlpool dishwasher
I had the same problem on a Diplomat ADP8322 its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
Hope this helps
May 07, 2008 | Dishwashers
Will not Complete a Wash Cycle
hello.
Please consider examine the control panel and the circuit of the machine maybe some connection setting is lessen.
melnavz
Mar 18, 2008 | Dishwashers
Hope this helps
Feb 10, 2008 | Dishwashers
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
