Question about Fisher and Paykel GWL11 Top Load Washer
The lights come on, but the machine doesn't start
My machine is 12 years old. It has been pretty reliable until today. The lights on the display panel come on and then nothing happens when you hit the Start button. Any suggestions welcome.
  • Fisher and P... Master
  • 713 Answers
Do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
Posted on May 06, 2010
  • luisa_sgro Jul 08, 2010
    Hi just read your posting.Now could you confirm the lights that are lit on your machine when it is beeping.Also could you please supply the model number of the machine.Looking forward to your reply.
Fisher& Paykel starts filling with water stop and starts then starts beeping with rinse light flashing have cleaned filters etc this even happens when I go to spin
Posted on Jul 06, 2010
Lg front loader wd-8050fh door wont lock
Hi just read your posting.Sounds like the door lock switch is faulty.Do you get any error codes on the display?Check the door latch that is attached to the door.It is the little hook that latches into the door lock switch.The tension on the hook should be quite firm.Please reply with answers to the question and the condition of the door latch.Looking forward to your reply.
Jul 14, 2012 | LG Washing Machines
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
No display on 190S monitor. It's 3 or 4 years old and has worked great until today. The green power light is on, but no display. I tried rebooting the PC and turning the monitor off and back on. The...
It can be the backlight inverter circuits went out, open it up and look for bad caps with bulging tops first, then look for 12~18vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Samsung 190S (Silver) 19 in. Flat Panel...
I just acquired a Pitney-Bowes 9720 at an auction. It is my understanding that it is a fax machine & copier. Does it have other features? How outdated is this model? Any information would be greatly...
It is about 12 years old. Also it is actually a Panafax UF-745.
It is a pretty reliable workhorse, however. if you ever see a C-54 code come up, it's a bad laser unit and you can then throw it away.
If you can find Panasonic's Document Management Software you can use it as a Printer and Scanner.
Good luck with it.
Feb 28, 2009 | Office Equipment & Supplies
Timer quits shutting the lights off and time flashes 12:00AM
Intermatic is a reliable mfg. if you have a it wired to directly to a light and only a light, you most likely have a defective timer. Bring it back and purchase a rotary timer with on-off switch. more reliable. I too installed the same type of timer and went through 3 before installing intermatics rotary timer/switch.
Jan 24, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Spin cycle quit working
you will need a lid switch, or a motor coupler
Jan 08, 2009 | Washing Machines
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Heater won't start error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Jun 15, 2008 | Rinnai Heating & Cooling
Fisher and Paykel GWL11 Top Load Washer Logo
348 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
