Chimei lcd monitor CMV T38D - model
Hi, I own a Chimei lcd monitor CMV T38D - model number A201 P1 - H03
Today it has been malfunctioning when I turn the screen on, it does not display anything. The light which shows the power is on ( at the side of the screen) which normally stays green when the screen is working now only flickers (flashes) it does not stay green. I have made sure all cables are properly connected and pushed in properly. I have had this screen for approximately 2-3years. How can I get my screen repeaired in Australia, I live in Sydney, New South Wales.
Sorry i could not find the product in the product categories
Thanks,
David
dodgecharger
  • 254 Answers
SOURCE: BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Posted on Sep 17, 2007
  • 99 Answers
SOURCE: No signal on first boot
This would usually indicate that there is a problem that is causing your computer to not boot correctly all of the time. What you have described could be many different problems and without more information I cannot say which one it is.
1. Hard drive. I have ran into Hard Drives that for some reason do not start up correctly right away when you put power to them. This can cause the initial startup to hang possibly indefinitely.
2. Video Card. Something probably firmware is causing your video card to not start up properly when power is first applied.
3. PSU. The power supply could cause similar problems if it cannot supply enough power because the highest power draw is when you first turn on the computer. When you push the reset button the power is already being supplied to most of the components and the ones that did not have enough power to start properly before can do so now.
4. CPU. If the CPU has some minor problems it can cause similar problems. In any case to fix it you can try clocking down the CPU but you are better off replacing it.
5. RAM. I have had similar problems with RAM. Clocking down the RAM fixed the issue.
6. Settings in BIOS. I would check to make sure the setting for init display on boot is set for PCI-e.
Posted on Nov 12, 2007
SOURCE: Graphics display
you need to download the latest graphics driver. check what u have in device manager. i think u have a sis chipset. go to sis.com.tw and download drivers. also, you will hardly be able to run any games as the chipset u have is incapable of decent 3d.
Posted on Jan 29, 2008
SOURCE: The screen doesn't display anything and the power button is flashing green
http://www.fixya.com/support/t661302-lcd_monitor_green_power_light_blinking
Check out my link, I repaired my flat screen monitor myself.
Posted on Jun 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Posted on Sep 15, 2008
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
www.fixya.com/.../t14977283-broken_mounting_arm_chimei_cmv_222...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Dec 15, 2015 | Computers & Internet
I have A Chimei CMV 221D LCD monitor. I am thinking from memory it is a 17 or 19in monitor. It's black in colour. It worked well, loved it but one day I booted the computer up and the light went from...
boot your computer into safe mode that eliminates any special resolutions from your normal windows if your display is good in safe mode then your computer resolution is set at a level the monitor cannot use you then will need to reset your normal resolution to a lower level
Mar 25, 2017 | Chi Mei Corporation CMV-221D LCD Monitor
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
May 22, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Where can I download an English manual for a CHIMEI - CMV633A monitor. The ones on their site are only in Chinese. Thank You
try www.chimei.com.tw then you click on the English. it will give you the English version.hope this helps.or try www.scribd.com or www.w9drugs.org
May 07, 2011 | Chi Mei Corporation CMV-633A LCD Monitor
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Amptron CMV-922D 19" Monitor
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
