Question about Hotpoint RB787 Electric Kitchen Range
How much does it cost to replace an oven control panel
  • Hotpoint Master
  • 3,361 Answers
Depends upon your model number.
What is your model number?
Posted on May 06, 2010
Why doesn't upper oven heat?
Given that you already replaced the control panel your fault option include the over temperature sensor, the fan sensor and the heating element. The easiest and less costly one is the temperature sensor. The sensor is also the most likely problem.
Jan 20, 2016 | Ovens
Cvm2072sm1ss contorl panel
The keypad control board will need to be replaced, but due to the considerable cost, replacement of the microwave oven would be a better option.
Jun 24, 2012 | GE CVM2072SMSS Microwave Oven
What is cost to replace electronic oven control panel
From Sears
$151.11 for part Item # 1 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Wall-oven-Parts/Model-GBD277PDS8/1198/0125300/W0201067/00002?blt=06&prst=&shdMod=
Installation will be extra of course and if the repairman purcahses the control panel expect an upcharge
Jan 24, 2011 | Whirlpool GBD277PDS Electric Double Oven
I have a GE JTP70, The Plastic over control panel bubbled up.
Mine did the same thing...and believe me it even looks worse over time....look online it happened to a lot of people....GE won't do anything about it....it is a defect but they won't own up to it......They just want you to keep replacing the part, which cost a fortune. Mine oven cost over $1000 and I am stuck with a nasty looking piece of garbage in my brand new kitchen......can't afford to buy a new one.........I Will NEVER BUY ANOTHER GE PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 19, 2010 | GE JTP70 Electric Single Oven
The control panel went dark. Can only read it
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
Control panel for GE microwave
The control panel module is different from the membrane. Unfortunately these modules themselves are usually very expensive, perhaps 1/2 the cost of a new microwave.
Sorry.
Oct 06, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmore Elite slide in electric range and the oven will not preheat to temperature (even after 40 min.) The repair man says I need a new control panel that will cost me almost 500 bucks...Any...
Hi. the electronic oven control board actually costs 198.00 but, the labor charges will inflate the cost because of the need to disassemble and add new wire harnesses. On most models, this relay is separate from the actual control board and it is usually linked via, wires. I would check around to see if you could get a second and maybe a third opinion. In my experience, you should just be able to replace the temp sensor or relay and that should fix the issue. Normally, if the control board is experiencing any issues, you will see a error code of some sort. I would defiantly get a second or third opinion before allowing the service tech to do the repair. that repair cost seems to be highly inflated in my view.
Please rate and god bless:)
Apr 03, 2009 | Ovens
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Jul 08, 2008 | Whirlpool RBD305PDS Electric Double Oven
Hotpoint RB787 Electric Kitchen Range Logo
242 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
