Question about Vacuums
Cuts on and of then wont come back on at all for a
Kennmore Progressive Whisper Belt #116 20612003. Cuts on and off after a few minuets then shuts down compleatly. I read about the overload protector in the canister and has to reset but what could be causing it to do this. The power mate protector seems to be fine.
I had to slightly widen power plugs on hose by inserting knife blade between their segments so that they make better contact.
Posted on May 17, 2010
  • 20 Answers
Plugged up airway. filter plugged behind bag, or hose plugged could also have obstruction in nozzle.
Posted on May 06, 2010
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Feb 21, 2015 | Kenmore 25614 / 25615 Progressive Bagged...
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
Canister powerhead brush does not seem to spin when the carpet level adjustment is on any level other than "high". Could it be something as simple as needing a new belt and is there a...
The belt is worn/stretched to the point that it cannot take the load on low level setting due to more resistance against the carpet and there is also no signifagant difference between the two belts except for expecting a longer belt life from the whisper belt. While it is apart make sure there is no hair or carpet strands in the rollers and around the belt pulleys
Jan 18, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Power mate cuts off after a few secs.
You have a short somewhere. They can be tricky to find. You might need to take it to a repairman.
Dec 14, 2009 | Vacuums
Hoove Cyclonic Bagless vacuum shuts off after only a few minutes
The motor has a protective overload cutout device to stop it from over heating - this can be caused by a blockage of some sort in the hose or brushroll compartment or blocked filters.
After checking the above and it still cuts out, take it back under gurantee
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
74 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
