Question about Maytag MDG7600AW Gas Dryer
How do I remove the top and front panels of my Maytag MDG7600AWW dryer?
    President:
  • 1,554 Answers
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Posted on May 06, 2010
Testimonial: "Thanks. It's easy when you know how!"
How do I get the front of my maytag atlantis dryer off ?MDG7600AWW
hello gstevens1, dont feel crazy on this one, cause these are really tricky.
I'm going to explain this to the best of my ablility.
1. open the door and remove the four screws on the inside.
2. "roll" the top edges of the front panel outwards to disengage from clips underneath. Basically, at the top below where it angles off, you are going to push ("roll") the sides out (left side towards the left, right side towards the right).
3. tilt the front panel away from the machine and lift the panel off the bottom clips.
4. lift the door off the hinge and jiggle the door out of the slots.
I hope this helps you out. You can get it, it's just really tricky.
thanks,
Mike
Jul 24, 2011 | Maytag Dryers
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
How to remove top of Maytag dryer
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer
remove the 2 kick panel screws near the front panel by the floor swing the front panel upward and the top clips will release,then remove the 2 hex head screws under the top cover then swing the top cover up like a car hood and secure it so it doesn't fall and pull wires out,then remove drum and restring belt and then around the drum then around the tensioner and reverse the above procedure
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i remove the drum on a maytag top-loading washer.MAV 7000aww
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Jan 30, 2010 | Maytag Washing Machines
Maytag gas dryer, model #MDG7600AWW does not turn on
a thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Sep 12, 2009 | Maytag Dryers
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Dryers Logo
580 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
