Question about Maytag Neptune MCG8000AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes to "damp" and the burner shuts down. New humidity sensor did not help.
  • Maytag Master
  • 43,501 Answers
If you have a gas dryerI have the Maytag MCG8000AWW gas - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer TroublI have the Maytag MCG8000AWW gas - 2_bing.gifimg src="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Drum of Maytag dryer Model # MCG8000AWW is becoming black and dirty
I would start by taking the dryer back off and cleaning all the lint out. on mine there was lint by the burner and burning and blowing into dryer
Apr 06, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Takes 3-4 cycles to dry one load. Heating element lights up, but does not always light flame
there is a few things to check---first check the exhaust tubes to make sure they are clear of lint,and blowing through good,if not then the dryer will overheat shutting down the gas valve---if that doesnt do it then replace the heat switch located back by the burner,if that doesnt help then last case it would be the magnetic coils on the gas valve need replacing.
Jun 06, 2009 | Maytag SDG3606A Gas Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag Neptune MCG8000AW Gas Dryer Logo
718 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
