Question about Cozy (W352E) Heater
The heater pilot goes out when the wind blows outside of the wall where the heater is installed. The heater is only six months old, so the thermo-couple is OK.
  • Brian Niten May 11, 2010
    Is this heater vented to outside?
  • 1,420 Answers
You mention that the thermocouple is OK, has it been changed or tested? This $4 part is usually the first thing to fail and I have found bad parts right out of the package. If I were you and I would contact the installing contractor to have them check out the following: Is the vent termination located as per manufacturing instructions (away from interior adjoining walls), Are the vent parts installed correctly, replace the thermocouple under the warranty, and check to make sure the pilot is both good and strong and it is hitting the thermocouple where it should. I have these heater installed on the top of Mount Washington where the wind blows at over 60 miles an hour and do not experience a pilot outage due to wind. The interior design of the venting system combats the wind effects. Good luck to you.
Posted on May 06, 2010
Rinnai wall heater lights but in about 5 or 10 minutes makes a wind blowing noise and goes out. Including the pilot lite.
The model number would be nice to know! I am concerned about the way you say it is vented.
Dec 07, 2016 | Rinnai Heating & Cooling
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
Procom ML 300TBA Pilot will not stay on when button released
It sounds like you need to clean the contact on the thermocouple.
Here is a link to the service instruction of how to do that.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 12, 2012 | Procom ML300TBA Heater
What makes the flame and pilot goes out about five minutes
wind, if there is any wind getting in your flu it will blow out your pilot light
which heats the thermo coupling and keeps your gas valve open its a safety device so if pilot blows out gas valve shuts down so as not to leak gas hopes this helps
Jan 23, 2012 | Heating & Cooling
Two-sided wall heater, re-igniting the pilot. Where does the match go?
http://www.comfortgurus.com/specs/williams/direct_vent_furnaces_install_manual.pdf .look at page 9-10 for lighting. no match needed should have a clicker,red push buttom. other than that there will be a small window that you can open and light with a match. if the wind is blowing you may need to cover the outside vent with somethig to keep the maych lit.
Feb 07, 2011 | Williams 1403622 Gas Compact Heater
I have an old gravity gas furnace with a PG9 pilot generator. The pilot goes out once per week. How would I install a new one?
first of all check to see if you need a vent stack wind might be blowing it out if ok then check to see if spider web in pilot generator if ok replace pilot generator turn off gas then follow the small silver tube down under replace the pilot generator
Dec 31, 2010 | Teledyne Laars IGNITION TRANSFORMER
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
I have a Rheem direct vent gas water heater. When
If you are not seeing a spark at the pilot assembly where the pilot flame lights, then it is probably not sparking in the right place. You may have a short in the wire or a cracked porcelain ignitor, causing it to spark elsewhere. If you can remove the access panel, you may have to relight the pilot manually with a butane lighter. To resolve the issue of the flame blowing out, make sure your vent outside has a cap on it and that the vent is not partially blocked with a bird nests, etc. Hope this helps. Douglas
Jun 27, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have an Ascot wall hanging hot water heater.The wind frequently blows out the pilot light. Can I make a safe housing around it to protect it from wind and rain
Yes you can, but make sure that it has access to air. Leave at least 6" of space between the shelter and the pilot. Is it outside? I've never seen one outside.
May 29, 2009 | Water Heaters
Cozy (W352E) Heater Logo
337 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
