Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
No picture was runnig fine-- suddenly- no picture- al connections hooked
  • 11,361 Answers
You need to find out if you have 24vdc at the inverter fuse, it can be that the 24vdc power supply is not working either.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Posted on May 19, 2010
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
NEC 17"1700M Works fine most
Either an overheating video-card, or a loose connection between the video-card and the monitor.
Jun 25, 2011 | NEC MultiSync LCD1700M (White) 17 in. Flat...
Sound but no picture
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Good luck...
May 29, 2010 | Toshiba MD14FP1 14 in. TV/DVD Combo
Flashing blue lights on the front
check the hard drive connects
Apr 20, 2009 | Computers & Internet
Bogging and backfiring on my atk 605
then all of a sudden it started bogging at certain RPMs. Then it would'nt start for a while. It runs fine at idle but once the throttle is turned more that 1/4 turn it just sputters and backfires but does not stall... any suggestions? Spark plug and battery can do this.QuickConnects or check injector plugs make sure both are injecting,
Nov 10, 2008 | 2003 ATK 605
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Feb 22, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
196 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
