Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Cannot reset remote to garage door opener Sears craftsman 139.53681B
    President:
  • 3,197 Answers
If you are sure the battery is good then try to program the remote by holding the button down on the remote and then pressing and immediately releasing the smart/learn button. If this doesn't work and you have another remote that does work then the remote has quit working.
Posted on May 06, 2010
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a sears craftsman garage door opener. I initially replaced the outside opener with a CLK1 - it worked fine after a chat to clickerproducts. Now I have replaced both the car remotes and no matter...
It sounds like you bought the wrong car remotes. The model number for your opener is on the end closest to the garage door. Using it you can get the correct remotes.
Jan 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working on Craftsman 53975 garage
It sounds like you have a logic board problem. If your remotes work at all it is not a programming problem. You could pull the logic board and check for loose connections especially around the small transformer. 18 years for an opener is very lucky. Their average life is about 1/2 that.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a sears garage door opener with two openers and one code remote (mounted outside of the garage). I had to replace a battery in one of the openers and when I went to reset it I accidentally reset all...
Keep the remote that works with the keypad and replace the other remote with one of the same model. This is a common problem and the only cure is replacement.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman remote -- new battery installed..
close the garage door, press the lock button so that's it's blinking, press the red reset button on the craftsman, then press the remote.... that should work
Feb 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote and Keypads open neighbors door
Hold down learn button for 8 seconds. This clears the memory for all remotes. Then reprogam your remotes
Oct 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
422 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
