Question about Troy Bilt 5.5hp Self Propelled Mower
I don't know which way to turn the blade-retainer bolt in order to loosten it and remove the blade for replacement. I am afraid I will break it off if I go the wrong way. Are the threads standard rotation(righty-tighty, lefty-loosey) or are they reverse threads(the opposite)?
  • 2,100 Answers
You got it, righty tighty, they put right hand threads on most lawn mowers and spin the engine in the direction that won't spin the bolt out, so you don't need to torque it on there with 50,000 lbs of torque, Just snug it up, then you can get it off again when you have to. A buddy of mine goes through blades like the Tasmanian devil, he grinds them with a wheel and puts them on with an impact driver, so he has to get the impact out to get them off, no curbside repairs for him. I tried to show him how to sharpen the blades with a 4 1/2 inch disc, but he would have it. He has a pile of ground down blades!! Get a piece of pipe on your ratchet handle to get the bolt loose. Get a pair of gloves on to hold the blade. If it is a left hand thread, I want to know about it. Hope this helps.
Posted on May 06, 2010
My 1994 Sedan Seville needs an alternator how do I change it
The alternator in your car is one of the easiest fixes you can do. First, remove the NEGATIVE (-) battery cable.
You must relieve the tension on the serpentine belt by loostening the retaining bolt, then remove the wiring harness plug from the back of the alternator, then remove the two retaining bolts from the alternator. Reverse the procedure to install the new alternator, making sure that belt tension is adequate. Replace the netgative battery cable last, and test.
If the serpentine belt is loose, replace the belt.
May 11, 2015 | Cars & Trucks
Simplicity 44" mower blades
Thank you for the great picture. You should be able to wrap each blade with a towel or large rag and grip it with your hand whilst you put a box end wrench or a socket & rachet on the bolt and turn it to the left ( counter-clockwise) and loosten the bolt and remove both blade and bolt. Put them back on the opposite way. Do not use an open end wrench, pliers, vice-grips, or chanel-locks as you can round the corners of the bolts. Be certain the box-end wrench or socket fits the bolt exactly.Tighten the bolt back on with the same tightness as you removed it. A tiny bit of oil or grease on the bolt's threads will help it go smoothly next time.
Be blessed.
Jun 16, 2013 | Garden
Is the retaining bolt on the blades LH or RH thread , as the bolt is firm in both directions
I don't know. Having said that, I would sugg3est you smack the bolt a good single solid blow then try RH again. BTW - Lefty Loosey ... Righty - Tighty.
I would expect it will be on very tight ... you might want to spray a product called Liquid Wrench or other penetrating oil on the bolt and let it sit for a while before you try again.
Try not to break it ... but if you do ... it is not the end of the world. You can drill it and use an "easy out" to remove the broken stud from the hole. Get help on easy out and drill size before you start if it gets to this point.
May 02, 2011 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
1998 mercury sable.need to change vss,does this have to be done from underneath vehicle'am a little afraid of breaking exhaust bolts
Vehicle Speed Sensor (VSS) Removal
  1. Raise and suitably support vehicle.
  1. Remove dual converter Y-pipe from exhaust system. -
  2. Remove heat shield from transaxle.
  1. Disconnect vehicle speed sensor (VSS) electrical connector.
  1. Remove VSS retaining bolt and remove VSS from transaxle.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten VSS retaining bolt to 5-8 Nm (45-70 lb-in).
Mar 22, 2011 | 1998 Mercury Sable
Which way do i turn bolt to get blades off right or left
hi, look at the way the blade spins. the bolt is made to tighten with the blade so that it won't come off during operation, so just go the opposit way that the blade spins to loosten it.
Feb 25, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
How do i change a 10 inch blade on my table saw
Howdy, Start by unplugging the machine (mandatory safety nag, sorry) then jam a nice piece of 2 x 4 in the teeth of the blade and remove the red blade surround plate. Use the blade wrench or crescent to loosten the side nut by turning towards the point of the teeth on blade. Remember the order of any washers as you remove, and replace in reverse after adding new blade ,being careful to orient the blades in the same direction as the original. Make sure all is snugly tightened and replace all guards to finish. Ta da!
I hope this gets you quickly back to making sawdust:)
Regards, Farmerbear at FixYa.com
Sep 08, 2010 | Craftsman 10" Table Saw
How do I remove the windshield wiper motor from a Ford F-250?
2002 Ford F-250 Windshield Wiper Motor Removal & Installation 1. Turn the ignition switch to the ON position. Turn the ignition switch ON until the wiper blades are straight up, then turn the ignition switch OFF. 2. Disconnect the negative battery cable. 3. Remove the right-hand and left-hand windshield wiper arm and blade assemblies. 4. Remove the cowl top vent panels. 5. Detach the electrical hardness connector at the windshield wiper motor assembly. 6. Remove 3 wiper motor (module assembly) retaining bolts and remove the module assembly from the vehicle. 7. Remove the wiper linkage retaining bolt and remove the linkage from the wiper motor. 8. Remove 3 retaining nuts and remove the windshield wiper motor To install; 9. Place the windshield wiper motor in position and install 3 retaining nuts. Tighten to 10-12 ft. lbs. (12-17 Nm). 10. Connect the wiper linkage to the windshield wiper motor and install the retaining bolt. Tighten the bolts to 14 ft. lbs. (20 Nm). 11. Place the wiper motor (module assembly) in position and install 3 retaining bolts. Tighten the bolts to 6 ft. lbs. (9Nm). 12. Install the electrical hardness connector to the windshield wiper motor. 13. Connect the negative battery cable. 14. Allow the windshield wiper motor to cycle several times while checking for proper wiper motor operation. 15. Turn the windshield wiper motor to the OFF position to park the wiper motor in the park position. 16. Install the cowl top vent panels. 17. Install the wiper arm and blade assemblies. Install the retaining nuts and tighten to 22-29 ft. lbs. (30-40 Nm). 18. Connect the negative battery cable. 19. Check the windshield wiper motor for proper operation and the wiper arms for adjustment.
Nov 09, 2009 | 2002 Ford E250
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Oct 30, 2009 | 1997 Ford Thunderbird LX
    Need to replace the left rad fan motor, any ideas on how to do it if i have the new part?
    1. Remove radiator from vehicle.
    2. Remove fan shroud retaining bolts, and cooling fan motor/blade/shroud assembly.
    3. Remove fan blade retaining clips and blades.
    4. Remove motor mounting screws and motors.
    5. If necessary, remove Constant Control Relay Module (CCRM).
    6. Reverse procedure to install. Torque CCRM screws to 40-56 in lb, and shroud retaining bolts to 24-48 ft lb.
    May 27, 2009 | 1996 Lincoln Continental
    How to remove & replace center AC / heater vent in 2001 Honda Civic ?
    They are held into the dash with plastic "spring" out retainers on the dash register. Use a thin blade like a putty knife to disengage the locks.
    Jul 06, 2017 | 2001 Honda Civic
    Troy Bilt 5.5hp Self Propelled Mower Logo
    274 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
