Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Stove latch on G.E. self cleaning ove is closed and will not open
Stove latch is closed and will not open renter thought it was a child safety lock and closed it to cook chicken fingers and now can not get door to open
    Problem Solver:
  • 7 Answers
Let cool down and should open
Posted on May 06, 2010
I have a 2002 Ford explorer and I can't figure out how to get the child safety lock off. The door doesn't shut now due to trying to disengage the lock. What can I do?
the child safety lock is normally a small lever at the edge of the door and has no effect on closing a door
it just prevents the door from being opened on the inside
what may have happened is that the door lock mechanism is in the 1/2 closed position and will not allow full lock (close) to occur
place a small screw drive under the latch or tongue of the lock and pull out as you press the door handle as if opening the door
that should then place the latch in the correct position for latching the door when closed properly
Sep 30, 2016 | Ford Cars & Trucks
What is a F90
A sledge hammer will just cause more problems ;-). You might try holding the light switch in when putting it in clean. Cycle through the clean cycle and then shut off the clean cycle. this may let the lock motor reset to open. There is a possibility the lock motor has gone bad. This may need a repairman.
Oct 06, 2014 | Kitchen Ranges
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
Mcclary stove
One thermostat (sometimes at the back of the stove) is open/blown or the door locking assembly has failed. To open the door you may remove the back of the stove; take the door locking assembly apart to release the long wire that hooks the door close.
On some models you can see the locking the latching mechanism through a **** in the top front and can play with the mechanisms there to release the door.
Then you can begin to figure why the door latched in the first place.
Oct 20, 2013 | Kitchen Ranges
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Door won't shut
I had the same problem on nearly the same day. The rear door would not close, and then in trying to fix it I flipped a latch closed. After trying all the child safety and power locking features, I just poked around with a small screwdriver until I could open the spring that held the latch closed. Once I got that open, the door worked normally.
Jul 11, 2008 | 2000 Volvo V70
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
224 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
