Question about Insignia 42" LCD Flat-Panel HDTV
My Phillips PLATTV TV doesn't turn on at all. It doesn't ahve any power button. can you help me?
  • 10,515 Answers
More likely it is Power Supply Board. You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
Getting a Service Manual for this Model could be tough, but i would be able to ask few vendors, in case problem would not be resolved. Usually, you could easy repair the Power Supply Board, if you could catch Few Bad Caps.
Note - I am Assuming that all the Cords and Connections are Fine.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 06, 2010
Phillips 409fl7505d/f7
I once had a problem with a Phillips tv.It was less than one year old and one day ,all of a suddenm a black screen came up.I elarned it was called the "black screen of death" and that other people had gone through the same thing.Someone online had actually written to Phillips and they had gotten a new TV form them,so I tried the same thing and amazingly,Phillips gave us a new TV and came and took the old one.The enw worked fine. So you may have a lemon on your hands.Unfortunately, I do not have the letter I sent to them but the replacement they sent me was part of their "Rapid Replacement" program.This wa sin 2008 so I'm not sure if they still ahve it but it may be worth a try.
Apr 09, 2013 | Philips 40PFL3705D 40 in LCD TV
Phillips tv wont change channel
tried with pressing the channel button at the panel tv or using with the remote controller doesn't work?.
Oct 26, 2012 | Philips Phillips 2422-549-01929 Tv Remote
My 60 inch phillips tv, I turned it off the other night and now all i get when i turn it on is the power button flashing green. 6 quick flashes and then 1. I need my tv, plz help
Try a new Web search for your brand. Try looking for a Diagnostic trouble code of 6-1 and see if you can pull up parts of a Service manual using that search routine. Try Phillips trouble codes, Phillips Diagnostic Codes, or your model# in the search.
It sounds like it went into a default Diagnostic mode. If you have a Remote with extra functions it may get you into the Diagnostic menu.
Dec 20, 2011 | Televison & Video
Will a Phillips Universal operate a Samsung DVD-2000, and what ar
YES! if you have a universal remote look in its manual and program the code for your samsung into it. there are some buttons like SET and TV1 2 etc Select TV1 and SET buttons a red LED comes on, enter the code (eg: 013) the red LED goes out Press set aain and then press power on remote TV shoulod turn off if it doesn;t try anothyer code until you have control of the TV
Aug 11, 2009 | Samsung Televison & Video
Code for p1300ntv to work with directv remote
You can "manually" find your code by  1. pressing tv button on the remote 2. press and hold setup until TV button blinks twice 3. press 991, the tv button should blink once 4. slowly press and alternate the power and tv buttons until tv turns off.   5. press setup to lock in the code when tv turns off.
hope this helps,  j
Jan 14, 2009 | Disney 13" TV
No button for code search ?
Hold The Tv Or Device To Be Programmed and hit power with it. then hit power until it turns on or off. then hit enter if you have one or hit tv/dvd/cable again. Hope This Helps
Jan 05, 2009 | Sylvania 6413TC 13" TV
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Insignia 42" LCD Flat-Panel HDTV Logo
26 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
