Question about Maytag Dryers
My dryer has power but won't start
My dryer has power, the inside lights are working, the control knob lights work, but when you push the control knob button, the dryer does not start. The dryer makes no noise when the button is pushed. The lint filter is clear and the lint filter is cleaned before every load. The dryer dried the clothes properly on the last load.
    Novelist:
  • 101 Answers
It sounds like one of two things. First of all, if you could let me know the make and model of your dryer, I can give you a more direct answer. But in the meantime, it sounds like its either the door switch is bad...and this is mostly on the upper right side of the dryer door - inside, where the door closes. Or, it could be a bad fuse - which is located on the lower back of most dryers. It has one screw holding it. It's about 1 1/2" long, and has two wires going to it. You can remove the wires and check continuity. If there's continuity (a closed circuit), then its fine. If not, then its bad! You can find either of these parts at your local appliance store. The way to check, or replace the front switch is to open up the top of your dryer. Use a straight edged flat screwdriver to pry open the top of the dryer. It just pops up, and then you can see the switch down on the right side where the wires are coming from, and it should be plugged in to the feed wires coming from the back of the dryer. Don't concern yourself with this part yet. Its all self-explanatory when you see it. Let me know if you need further assistance. If so, please send me the make and model also - that way I can guide you directly to the problem. Good Luck, and I hope this works for you. - Jim
Posted on May 06, 2010
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
'lll
Aug 17, 2011 | Dryers
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
Dryer will not turn on
if dryer is elect ck the power first /it may have blowen the breaker . one side . this happens a lot . turn both lines off and then back on . . if ok go back to controls and ck w ohm meter . "Q" why were you removing panel . did you have another problem ?
Dec 23, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer
sometimes the control knobs that you set your dryer to different heating sets will go bad but it is in the control panel some where i whould say it is the heating setting
May 19, 2008 | Whirlpool GEW9250 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Feb 07, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
222 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
