Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bad punp I was told that when the pump goes out that there is another part that fails most of the time is this true thanks sean
  • 20 Answers
Pumps in the unit you have seldom fail. front water tank could be warped. or its gonna be a issue with the solenoid .
Posted on May 06, 2010
Filter queen power nozzle recall
you mus call them, and explain your sense, and they will accept your comments, and proceed according your will. Do it, Do not waste your time.
God bless you
Jul 23, 2012 | Filter Queen Majestic Canister Vacuum
I have no spray on floor but have spray at hand
Same Bissell 9500 cleaner. Hand piece works fine, but cant spray water / cleaner when doing the floor. I've made sure the rollers are working and taken my air compressor on low psi and blown back to make sure the floor spray lines are clear...
Going to take apart and check the pump today.
Still looking for help! Thanks
Sean
Apr 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell little green machine will not spray
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
Mar 22, 2010 | Bissell 1425 Little Green ProHeat Handheld...
H3000 doesn't start.
No fuses. The only thing in the circuit is the switch, so it's probably that. Good-luck.
Kirk Thompson
San Juan,PR
Oct 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Filter replacement
Yes, it's true.
Here is a link to the manual:
http://www.eureka.com/service/manuals/70239B.pdf
Click on the link and then save it to your computer for future reference.
The filters are described on pages 15-16.
You can find them at any good appliance store, or google "vacuum filters". You'll get lots of options.
You can always go to www.eureka.com and click Customer Service.
If this solution has been helpful please take a moment to rate it. Thank you.
Oct 25, 2008 | Eureka Whirlwind 4383 Upright Vacuum
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water spray in the front of my bissell not working
Check the belt on the pump. These should be changed once a year. It is also possible that the heater is plugged. This problem will require a technician to repair.
Be sure that there is shampoo solution in the small tank and if not, turn the adjustment knob to "off" or the machine will draw air into the system and the punp will get a vapor lock and not work.
Mar 29, 2008 | Vacuums
Vax problem
Could be a bad pump.
Feb 07, 2008 | Vacuums
Not oscillating
Hope this helps!
Inside the gearbox there is what should be a 2 pronged fork you may only be able to see 1 of these the other may be broken, the fork goes each side of the armature bearing. If the fork isnt broke it may be the armature bearing that fits inside the fork.
Hope that helps. Sean
Jul 26, 2007 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
216 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
