Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Carborator overfilling the bowl gas bubbling - Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
  • 2,100 Answers
Your float is stuck open and needs to be set, a piece of dirt gets in there and holds the float open, sometimes it is just too high. You can take the top of the carb off and set it. check out the valve while you are in there. Hope this helps.
Posted on May 06, 2010
We have spark and gas but still won't start
you need to take the carb off and give it a full cleaning not just drop the bowl.
Mar 16, 2014 | MTD Genuine Factory Parts MTD 954-04014...
How do i get the carborator off a 2010 polaris scrammbler 500 h.o.?
esasiest way is to take front plastic off then taking off your fuel tank.doesnt take long.
Jun 09, 2012 | Garden
Fuel leaking from hose on bottom of carburetor
This happens when the float in the bowl sticks open. On a carborator the bowl holds gas. When the fuel pump fills the bowl the float raises and is pushing a needle valve that shuts off the gas until the float goes down and the needle valve opens and adds more gas. sometimes is sticks or the needle valve doesnt seat properly. You should rebuild it, buy a carb rebuild kit for your type of carb. It comes with new needle valves, just remember how it came appart.
Good luck
Robert
Oct 04, 2011 | Motorcycles
I have used my mower 3 times and it is leaking gas out of the carborator faster than i can put it in.
You have water in your gas tank or gas in your carburator float or a needle valve that isn't seated correctly. First empty the gas in your fuel tank into a clear container. If their is water ,you will see it with the gas. Second remove the bowl from the bottom of the carburator careful of the gasket, check for water in the bowl, clean bowl. Carefully remove float and needle valve. Shake float, listen for liquid inside. Check tip of needle valve for damage or corrossion. These three examples should be one or all of your problem. Clean and reinstall all parts. Add fresh gas and you should be ok. GOOD LUCK.
Jun 30, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Changed fuel pump and the gas still isn't getting there to start the car, if you pour gas directly into the carborator it will start but die quickly what could be wrong with it
Try changing the fuel filter. If no help, look into the float bowl on the carburetor for lack of fuel. If so, remove the float and needle-valve to check for a local clog in the needle-valve seat area. If the bowl appears to be nearly full, then check the screw-in jets in the bowl bottom for plugging. Hope this helps!
Oct 10, 2010 | Plymouth Breeze Cars & Trucks
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Gas getting to carborator but not starting
ok buddy strip carb off and 4 screws on the bowl and inside you will see the float slide the pivot pin out holding the float in and the float will come off with the inlet fuel valve still attached take this off and the tab it was still connected on you need to bend that down wards to allow more fuel in the carb and into the engine or another thing could be the main jet blocked check the jet first blow down it if ok do the float bit and get back to me 2774fd5.jpg
Sep 22, 2009 | 2000 kawasaki KLX 300
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
No power - won't start. Have checked fuses and sprayed WD40 inside electrical connection but still dead
If the mower has been sitting all winter and has not been run, the the gasoline in the carborator has probably went bad and has left a thin coating on the valve inside the float bowl causing it to stick shut. The float bowl should be located on the bottom of the carborator. If the valve is stuck shut, then you aren't getting any gas through it. You should take your spark plug out first to be sure that it is firing when you crank the engine. Do this by removing the plug, then hooking back up to the wire, then hold it against something metal on the engine so that it is grounded in the area of the threads. While holding it with a pair of pliers have someone crank the engine over. If you see the blue spark in the gap on the end of the plug, then you know it is getting electrical fire, BUT be careful not to get shocked...lol. If there is spark, then the it is going to be the float valve. First you should get an empty gas can to catch the gas in the mower, because you need to remove the gas line where it attaches to the carborator, and drain the tank. You can now remove the bowl, usually pretty easy with only a few screws, then there will be a small lever arm which has the floats attached to it. remove it carefully and you should be able to remove and examine the needle valve just above the float lever arm. If it is stuck or if it looks like it has a varnish on it, then clean it up really well with some carborator cleaner. Both the valve and the valve body should be cleaned up good, as well as the bowl and float. Once reassembled, that should fix the problem. There are several additives on the market which you can buy and add to your gas, called stabilizers, which will prevent the gas from going bad during long periods of non use, eg, winter...
May 02, 2009 | Garden
Toro Model 20017 pump bulb, runs 2 seconds then quits ....
I had the same problem. I took off the carborator and cleaned every opening I could find. As I was reassembling it, I noticed the holes in the bolt that holds the bowl on were plugged. I hadn't notice that fuel flows through the bolt to the carborator. I cleaned them out and the mower started fine. I suspect it was that all along. I would try cleaning out those holes before you take off the carborator.
Mar 19, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
