Question about Zanussi ZWF1430W Front Load Washer
Wont finish wash cycle, comes up on digital screen e20
  • 269 Answers
Have you checked the pump/filter,E20 relates to that.
If water is still in the drum you will need to drain it out either thru. the little drain hose by the filter if it has one (slow job).Or if you can get the machine near an outside door then undo filter plug and let water drain outside.Once water is out then get a torch and check up inside filter housing if pump blade can turn fully.One way to check is to put machine to spin/drain then see if pump spins,if not then you need to find if an object is stuck in blade if you cannot free from front then you need to remove pump.As long as power is off incline machine back against unit or lay on its back.ON the side of the filter housing where pump is mounted there is a small plastic tab which you need to bend slighty with a pliers be careful not to go too far as it can break,remove cables from pump twist pump in an Anti-clockwise direction and remove.Check for any debris in pump also in pipes either side of pump,fitting is the reverse of taking out just note that there is a longer cut out to the others which will only line up one way with pump.re-fit cables and filter try and check for leaks.
Hope this was helpful.
Good Luck.
Posted on May 06, 2010
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
Washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
May 24, 2010 | Frigidaire GLTF2940ES Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi ZWF1430W Front Load Washer Logo
190 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
