Question about Toshiba Satellite L500 Series Notebook
Blank screen on toshiba satelite laptop when I try to power it on
  • 160 Answers
If there is power and fans are running, seek the service method if you have an extended warranty, if not take it to a local computer repair shop or buy a new one.
Posted on May 06, 2010
KingDWS
  • 1606 Answers
SOURCE: the screen of my laptop Toshiba Satelite
When you first start you should see a few lights flash on. The power light should be on steady and the one that indicates hard drive should blink off and on as the computer gets what it needs from your hard drive. If you don;t see that or hear any beeps then you may have a serious hard ware problem.
First thing to try is to hook up an external monitor and turn on the laptop. You might only see a flicker or flash on the external or you may see a proper image. This depends on how your laptop is setup. If you don;t see anything or can't get a monitor to use then you need to check the display on the laptop.
Turn it on and wait until you think it has taken about the right amount of time to normally boot up. You need lot so f light to do this but look at the screen and see if you can just make out a ghost image. Or what looks like a ghost image. This will look like your desktop or parts of it. It will be quite hard to see unless you get just the right angle and light. If you can see this then your problem is the back light in the laptop display. The ghost image is actually your normal LCD display with the back lights. The LCD creates the image but is too dark to see and the back light shine through it much like a projector does. If this is the problem repairs are about $150 (and up)
If you don't see any light or images then you can have a cpu problem, a memory problem or a motherboard fuse problem. These are a bit harder to fix as the laptop needs to be completely taken apart.
The back light is a typical problem on all laptop regardless of make or model. The others usually indicate a more serious problem. For example Satellites are prone to run hot and if the fan or colling doesn't work well enough then the cpu can overheat and be damaged. Ram chips can be replaced if the error in in the external ones not the ones on the motherboard (some models) and fuses are simple to replace but require a tech who can repair surface mount parts.
Once you have an idea of the problem then you can figure out how or if to get it fixed. Check to see if you have any warranty it will definitely cover this. Have a good idea of what replacement cost is. There are several places that can repair the laptop even if it is out of warranty but you need to watch the cost. I wish I had a better suggestion for you to follow but it seems like your laptop is headed for the shop.
Posted on Sep 01, 2009
Testimonial: "Thanks a million for the detailed solution alternatives. It is back working though after removing the battery and leaving it for sometime. "
  • 42 Answers
SOURCE: Laptop screen stays blank on powerup
You would be well advised to hit F8 and do a safe mode. Then check the disk. More details here: http://annoyances-resolved.blogspot.com/2009/09/laptop-wont-boot-and-shows-blank-screen.html
Posted on Nov 19, 2009
asingh1225
  • 122 Answers
SOURCE: my Toshiba Satelite 4090XDVD laptop has stopped woking
hello, try unplugging the power cord from the laptop and then remove the battery too, wait for 15 seconds put the battery back in and plug the power cord back in, now try to power the laptop back on and see if it works.
let me know if it doesn't and if you see any change in any of the lights blinking.
Regards,
Amar Sondhi
Posted on Dec 05, 2009
nileshsingh2
  • 246 Answers
SOURCE: My toshiba satelite laptop beeps continuosly, non-stop
Beep happens when the systems memory ram is partly or fully damaged. Try to replace with the same type, if you have one. Other problem happens when the key is stuck and gives beep sound whenever it is switched on. But in these case, the system will come on, and you will be able to use the laptop. Im quite sure it has the Ram problem, It is located at the back of the laptop, which is screwed with the panel cover over it. Thanks
Posted on May 19, 2010
Geekman
  • 32281 Answers
SOURCE: laptop powers on but goes to a blank screen and stays there
Your problem could be a backlight problem, it is caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jul 14, 2010
Toshiba satelite L305-s5968 need my screen to light up
Try FN+F5 after you power up. Hold down the FN key and press F5 This will toggle between the internal LCD and the external monitor output.
Jun 10, 2014 | Toshiba Satellite Computers & Internet
Blank monitor when laptop is used on charger
I would check the VGA driver is up to date and most of all the power options are correct.
Jun 03, 2014 | Toshiba Satellite Computers & Internet
I have a toshiba satelite L645D-S4056 which does not power on
hi to tell you what from my knowledge it means the main board of the p c is bad or needs servicing give a technician to help you check it
Jun 18, 2017 | Toshiba Satellite PSK0QU01200D L645D-S4056...
My toshiba 1135 s1553 powers up but i have a blank screen
You said you connected your laptop to another monitor and nothing shows up - looks like a problem with graphics card/motherboard.
Dec 19, 2011 | Toshiba Satellite 1135-S1553 Notebook
Toshiba Satelite Asos screen is blank after logon
This indicates a hard drive problem, but! first remove the hard drive and re-seat it back in place, "sometimes it goes out of position" and is enough to restart it, if no change! use your recovery disc to reload windows. Now! if it fails to load up chances are it is probably a bad hard drive, but I recommend having it tested before replacement of the hardware.
Apr 01, 2011 | Toshiba Satelite 5205-S505 Notebook
Computer will not turn on just a loud tone
Turn off your laptop First.Then Relies your Battery of your Laptop.open the back cover And put off the RAM of your laptop CAREFULLY,CLEAN IT WITH SOFT CLOTH.again put the RAM in the RAM slot , Cover the case .Again put on the battery on the Battery case. Now Boot the laptop
Sep 11, 2009 | Toshiba Satelite 5205-S505 Notebook
Toshiba satelite p305 won't boot
Remove the battery and insert it after 10-15 minutes and then reconnect it and try...
Aug 23, 2008 | IBM ThinkPad 600 Notebook
Toshiba Satellite L500 Series Notebook Logo
303 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
