Question about Behringer XENYX 2442FX Mixer
Any known part on power pcb that goes bad? - Behringer XENYX 2442FX Mixer
  • digitalri May 06, 2010
    fredy2 -
    thnx for ur reply. This is more of a heat, or time delayed issue. After about 20mins I get distortion across all inputs/outputs.
  • Behringer Master
  • 5,603 Answers
There are no chronic failure parts.
Faders that get contamination in them can be a problem.
The external driver chips CAN be damaged when people connect the unit to amplifiers that are run from a power source at opposite ends of an auditorium for example, due to common mode ground loops and faults.
Setting up a system is one part knowing what equipment is needed and one part electrical engineering regarding safe interconnection of low level audio signals.
Posted on May 06, 2010
  • Fred Yearian May 07, 2010
    That sounds like a power supply problem...
    With heat related part failure QUICKEST way to find failure is using circuit cooler or "freeze mist".
    Check the supply voltages during failure.
Yamaha Piaggero NP12 all "A" and "Eflat" keys are dead.
If all A & Eb are dead it would point to either a bad connection between the keyboard circuit and the motherboard ( ribbon cable ) or possible diode problems on the keyboard PCB.
Initially open up and check connections are all tight and correct.
Did this just happen or has the keyboard been opened up?
Nov 27, 2016 | Yamaha Music
How to take the hum out of an amplifier
We would need more info to help you, but assuming you mean the amp hums with nothing plugged into it, you may need the caps replaced. This is not user serviceable and needs to go to the shop.
Oct 03, 2016 | The Music
I can't get power on my Casio lk-50. ? Help
Hi, There are several common reasons why this and most similar keyboards have this problem.
If you can fit known good batteries, and it works, this confirms the problems will be with the external power supply or connection.
Usually batteries are not available, so.......
Do the obvious.
  1. Is the power supply plugged into a known good mains socket?
  2. is the mains socket switched on?
  3. is the power supply plugged into the keyboard?
  4. is the keyboard switched on?
If the power supply is not the one supplied with the keyboard, then check it is compatible.
(You do not have to buy an expensive replacement power supply, a universal, regulated one, with a selection of connectors will be fine. Supermarkets and the like sell them.)
The manual, or a label on the bottom of the keyboard will tell you the voltage, current consumption, and whether the current is AC or DC.
Invariably the current is DC.
All the Casios I have are 9 Volts, (9V) and very few are more than 300 milli amps (300mA) More milli amps is fine, so the current can be the same or greater.
A TYPICAL power supply is likely to be:-
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
The power supply needs to be REGULATED.
Polarity
This is the way round the connector is wired.
Usually the center is negative (-) and the barrel is positive (+)
This information is molded into the plastic or on a label next to the socket.
On a replacement (universal) power supply, there will be a set of connectors, and when you have selected the correct one, the arrow on the end of the lead should point to the correct polarity symbol on the connector.
Fault finding
The most common fault is the power connector being broken or the solder has been broken.
Slowly moving the connector round, to find it works in some positions, is a sure indication that is the fault.
Repair is quite simple, but there are a lot of screws to take out.
Ideally, drill a hole in the case, where convenient, and fit a metal connector. Now connect to the PCB, in place of the original socket, with flexible wires.
Other wise if it is just solder failure, re solder and glue the socket with epoxy resin (Araldite) or hot glue from a glue gun.
Hope this helps, Chris.
Mar 15, 2016 | Casio Music
When I turn my yamaha YPT-320 on the panel lights up for 2 seconds then turns of any ideas
MY guess would be one of 2 things.
1) Power adapter faulty
2) Socket where adapter plugs in has a bad solder joint.
Turn on the keyboard and push the plug on the back of the keyboard up ( hold in upright position ) if it doesn't shut down / or alternatively doesn't work investigate solder connections to pcb for the socket. They often fail and break the track on the pcb. Repair as needed
Jan 30, 2015 | Yamaha Music
WE CAN NOT USE OUR CASIO KEYBOARD NOR FIND A POWERCORD #AD12ULWK1630 anywhere
Hi, This is a copy and paste from a similar question, please excuse my laziness........
Do the obvious.
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
Polarity
Fault finding
Oct 20, 2014 | Casio Keyboard Power Adapter
Swr 750x has a short
The 12ax7 preamp tubes will act just like that when they get old, in fact, this would be my 1st check before I go any further, other than ventilation and heat .Make sure you are using the right impedence output jack to match your cabinet. Make sure the effects mix level is not overriding your guitar signal. Also, make sure that your signal is not being clipped showing the red led's. Also, the variable limiter control, if turned up very high, will do that to a point similar to a compressor/limiter. I would definitely check the tubes for the crackling sound could be just that.
Mar 11, 2013 | SWR 750X Pro Series Bass Amplifier Head...
The green light flashes with no fan noise at all or any sound
You have a bad power circuit board. if you are tech-inclined,you can open the mixer's rear cover and check for bulging/leaking capacitors on the board. they will need to be replaced. Or just order a new PCB from Peavey. Rodger, in tech support, will be happy to help.
Sep 13, 2011 | Peavey 00511800 Escort Portable Sound...
When I plug the fc-5 pedal into a P95 piano, sustain in ON (either I press the foot switch or not) and when I unplug it, sustain goes off, and sometimes it is vice versa, pressing the switch doesn't...
Sounds like a loose wire to me (because the problem isn't consistent) the most likely suspect is the jack plug. Unscrew the body of the plug and check that the two wires are firmly soldered to the terminals inside.
If they're OK you can pop the cover off the footswitch and check that end. As far as I recall that end of the cable goes straight to a PCB (printed circuit board) so be very careful if you need to solder anything. If the solder around the wire connection is cracked, that's a dry joint and can be fixed with a small blob of solder carefully applied.
If all the cable connections are fine there's a problem with the PCB or the micro-switch mounted on it.
Jun 20, 2011 | Yamaha Fc5 Sustain Footswitch
Amp goes dead
A few things come to mind. The power transformer could be failing or a capacitor is failed or has a broken solder connection..or a series of bad connections. Spider II's and especially III's are known to do this sort of thing. There is nothing you can do to fix it without taking it to an authorized repair center with your receipt. Repair centers simply get a whole new circuit board to replace the existing one since most of the components are surface mount and programmed chips. If its the transformer then if may be more expensive to fix than it's worth (unless it's still under warranty). With dozens and dozens of components inside these amps, there is no way to pinpoint the problem without hands-on servicing. Check Line 6's website for your nearest repair center. Best of luck!
http://www.line6.com/support/serviceCenters/
Aug 25, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Behringer XENYX 2442FX Mixer Logo
149 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
