Question about Digital Media AL Tech MEDIAGATE MG-450HD Player
How can I reset my medigate 450 ..it wont recognize the 1 b hd at all
Windows wont recognize my camcorded
hi,
use the genuine inter phase cable, check the connecting point for dust or dirt, clean it with CRC spray.
Feb 13, 2016 | Sony Handycam DCR-SR80 HD Camcorder
How to reset BIOS for hp omni 120-1124 desktop
Most PCs will start up in BIOS if you hold down the delete key while you power up. My HP desktop is different, as you need to hold down F1, so try that.
Jul 25, 2014 | HP Omni 120-1124 All-in-One Desktop 1.65...
Problem with Samsung G2 HM641JX 640Gb
You want to check if a the drive is recognized by windows, initialized and has a partition. Watch the video.
Dec 24, 2012 | Samsung S2 Portable HX MU010EA 1 TB...
A770E3 MOTHERBOARD 4 GIG RAM SATA 1 TERABYTE HD SATA CD/DVD NETBIOS SEE EVERYTHING FINE. BOOT SEQUENCE FOR CD ROM 1ST PROBLEM. WONT BOOT ANY OS. XP PRO ORIGINAL DISK LINUX UBUNTU...
You can get a manual here:
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=450
Did you set the boot sequense in your bios ??
First your CD or DVD drive
Second you harddrive.
Harddrive must be in sata 0.
CD or DVD must be in sata 1.
Or look in the manual how the settings should be.
Good luck.
Feb 27, 2011 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I can't get a signal for my ps3; All cables are connected.
If it is a a HD television and you are using HDMI cables sometimes the television wont recognize them. sometimes reseting your PS3 will do the trick.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
Wont recognize ide drive on startup
When you boot,go into the bios. In the main section see if your drive is listed.
If not, turn off machine, open unit, check power and data cables
Harddrive are blue data cables. Also check to see if HD is slave or master. Jumper switches on HD. Clse unit and boot up into bios
in the main you should see you HD
in boot sequence.. see if you c:/ is in the list
bios will tell you how to put in list if not there
close and reboot
Jul 25, 2010 | Dell Dimension 4550 PC Desktop
Does not recognize HDD was working fine then died. reset RAM and HDD no luck
sounds like a bad hard drive, did it make any noise before it died? if so probally a head issue. if the bios sees it you can try a format and reinstall if not you will need a new harddrive. if the bios cant see it no use in trying format it wont work. you have to physically replace the drive. you may or may not be able to go bigger on the hd depending on the bios ability to reconize the hd. there are programs for the hd from the mfg. that will overcome this limit and they work up to a point.
Aug 03, 2009 | Compaq Evo N610C Notebook
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
i got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Nov 19, 2008 | JVC KW-AVX810 Car DVD Player
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
Digital Media AL Tech MEDIAGATE MG-450HD  Player Logo
Top Digital Media Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Media Audio Player and Recorder Expert? Answer questions, earn points and help others
