Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric II, Only prints Numbers
As stated above, i can only print numbers with what ever element I use. Will you give me a way to correct this problem?
Thank you. Clay
  • claytpe May 06, 2010
    Any Alphabet key that I press, prints only Numbers or other characters.
  • Lexmark Master
  • 12,061 Answers
Http://www.electronicspoint.com/ibm-selectric-typewriter-repair-t48510.html
http://www.covingtoninnovations.com/selectric/index.html
http://www.scribd.com/doc/279389/IBM-Selectric-III-Manual
http://www.search.com/reference/IBM_Selectric_typewriter
OK well if there are NO stuck key, and only prints numbers, then this unit has an electronic fault.. this used to be a common enough problem, many years ago as I remember it, an IC, goes faulty, and causes the number character generator to output & not the alphanumeric generator, You are going to have a difficult job to repair this unit. what you should possibly do is buy another one, if you really like using it. Because the cost of parts, plus the having to buy, a service manual, so you could know the IC, description and type number, to repair, this unit, would indeed, be close to or more than another one, I have seen them for sale,and are very reasonably priced. You also may even be able to buy a board to repair it, if cheap enough. I looked for a service manual too but couldn't find any free ones.
http://shop.ebay.com/i.html?_nkw=IBM+Selectric+II,+typewriter&_sacat=0&_stpos=&gbr=1&_dmpt=BI_Typewriters_Word_Processors&_odkw=IBM+Selectric+II,&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
Posted on May 06, 2010
    Master:
  • 497 Answers
Hello, can you please give me some more detailed description of your device? Also, is it a stand-alone, or does it connect to your computer? If it connects to your computer, what system are you running?
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
IBM Selectric II letter printed does not correspond to the letter typed
You could have a broken element (type ball). You could also have a broken or out of adjustment rotate or tilt tape. Those are the two wire bands that control the rotation and tilt of the element.
Dec 11, 2013 | IBM Office Equipment & Supplies
Broken metal wire in ibm selectric ii
You have either a broken tilt tape or rotate tape. One controls the tilting of the element (ball) and the other controls the rotation of it. If either one is broken, you will need a qualified technician to replace it and make any adjustment necessary so it doesn't break again.
Oct 17, 2013 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
