Question about M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
My m audio 1010 as a problem with a crackling sound I know it not the break out box because I have two and it worked fine on the other pci card
  • 1 more comment
  • sjkinguk May 06, 2010
    I have both of my Maudio 1010 connected one work fine no noise at all the other one makes crackling sound on the input and clear on the output the last time I used the the one with the problem was when I had windows xp and it was fine but have change computer and the os to windows 7 64bit and when I tried it the other day it had this cracking kind of sound on the input I updated the the drivers to 64 bit its not the break out box because i switch them around could there be problem with the pci card
    I did everything you said and the sound is still there and there is another thing I need tell you is that it clears itself of the crackling sound for few seconds then it come back. the crackling sound is like when you screw up and empty potato chip packet.
  • sjkinguk May 07, 2010
    I have two Maudio 1010 hooked to my computer one works fine no noise very clean the 2nd very clean on the output and cracking kind of noise on the input like a potato chip bag being screwed up also the noise goes away for a few seconds and then it comes back. the breakout box are ok I have swapped
    them around. every thing worked fine on windows xp now I have a new computer and running windows 7 64bit. could the pci card go bad? or is it something in the audio drive software?
  • 4,472 Answers
First thing I would do is hook the "bad card" back up to a windows xp machine and see if you still have the problem. It could still be an issue with windows 7. Have you contacted m audio at all about the problem? Once I have more information I can assist you further.
Thank you,
Lee
Posted on May 07, 2010
    President:
  • 1,851 Answers
Your idea is absolutely the correct direction. There must be a smooth interface between the two. I strongly suggest you first remove the 64 bit driver. Remove the sound card and see if the 32 bit driver shows back up. If the 32 bit driver shows back up - remove it. Then remove the card. With the card removed - take a pencil eraser and scrub the cards pins ] the copper looking things going into the pci slot. Look for any blockage in the PCI card slot. Also use AIR and push the AIR right into the Power Supply cage & push out as much dust - [ it's in there] as you can.
Now restart the pc without the sound card and do a quick search for the name of the sound driver. If you have the install disk and there are no little hangers on files - Put the disk in or run the file for 64 bit drivers. NOTE - just because the drivers work doesn't mean the software will work. Check to see the software it self will work. Be sure to know if the instructions ask you to install the card FIRST or NOT - -if first - shut the machine down and install the card. Once the 1010 is back in - boot everything up and check the driver is working. If it isn't working -or partially working - right click the program - properties and choose RUN AS XP.
This will cause your unit to work. If this doesn't work for you. Remove the card and install it in a borrowed or back up machine. If one card is working and one card just like it isn't - AND both are in the same machine swap their positions. Check to be 100% sure you have enough resources to run BOTH cards on that set up. To up tick the RAM is also a good thing. Put in the MAX ram for the machine as Win7 takes a ton of ram -more than any other pc operating system you have ever had. HERE ARE THE BEST DRIVERS
Best of it
Gary
Posted on May 06, 2010
  • 781 Answers
1. check your input levels (source output level) and lower them down to attempt to adjust
2. if using mic reduce the gain level
3. check the audio buffer size and increase as needed.
(see if you have a callibration routine that may need to be run to set the buffer size accordingly, audio application handles buffer settings differently, but the
options for changing buffer sizes are usually found under the program’s “setup”
or “audio preferences” menus
4. If you have connected your Delta 1010 to other digital
devices using S/PDIF or Word Clock connections, ensure that your
clock sources have been configured properly.
5. Try turning off
visual effects to see if audio issues are resolved. In Windows XP, go to Start
> Settings > Control Panel > System
6.some accelerated graphics cards use
excessive amounts of system bandwidth, preventing the recording buffer of an
audio card from keeping up with demand. This can cause clicks in the audio
streams. Reducing or turning off the graphics card’s graphics acceleration
feature often resolves this problem. In Windows XP, go to Start > Settings >
Control Panel > Display. Select the Settings tab and click the Advanced button.
Select the Troubleshoot tab and set the “Hardware acceleration” slider to
“None.”
source: user's manual
hope this helps
  • Francisco Cortes
    Francisco Cortes May 10, 2010
    where did you get the driver's from when you updated to win7 64bit. have you tried using the vista 64 bit version driver?
    have you tried to uninstall the audio controller that comes with your motherboard or disable this device in bios? some pci sound cards may require this to work properly as they like to be the only audio device in your system. uninstalled the pci card along with the drivers, then disable the built in audio device and installed the drivers for it then reinstall the pci card from scratch keeping in mind the configuration points provided on my previous comments.
  • sjkinguk May 11, 2010
    I downloaded drivers from Maudio site. I will try the other things you suggested, but the question is why is this problem not appearing with my other 1010 which is hooked up to the same system and working?
  • 493 Answers
To solve your problem do the followings. Test after each procedure then do the next.
1. Check the cable connections,
2. Reinstall the Delta 1010 drivers,
3. Lower the sources output level,
4. If you recently changed your computer's software or hardware configuration, try running the profilling (soundcard calibration) routine.
5. Increase the Delta 1010 Audio buffer size. (change from "programs setup" or "Audio Preferences" menu)
6. In Windows XP, Go to Start>Settings>Control Panel>System. Select the Advanced tab and click the settings button under performance. Select "Adjust for the best performance" from the window that appears.
7. If you have connected the Delta 1010 to other digital devices using S/PDIF or Word Clock connections, configure the clock sources properly.
8. In windows XP, go to Start>Settings>Control Panel>Display. Select the Settings tab and click the Advanced button. Select the Troubleshoot tab and set the "Hardware acceleration" slider to "None".
Hope one of these helps to solve your problem.
  • 3 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 07, 2010
    Hİ,
    I think the problem comes from Windows 7 64-bit operating system..Your software may not be compatible to that 64-bit operating system.
    If you install your operating system as 32-bit or if you work on XP operating system it may be fine.
    Hope this helps.
    ioktay
  • Ibrahim OKTAY
    You may run Windows Program Compatibility section on the Control Panel of Windows 7 operating system to check older programs.
    To do that;
    Control Panel > Programs > Programs and Features > Run Programs made for Previous Versions of Windows
    Hope this helps
  • Ibrahim OKTAY
    Ibrahim OKTAY May 11, 2010
    In my opinion, the problem is Windows 7 compatibility. You need to download Windows 7 compatible sound card driver.
    Please download your Sound card driver from this link.
    - Select Delta Series on the lest menu,
    - Select Delta 1010 from the other menu,
    - And Windows 7 (32-bit or 64-bit check your operating system setup) on the right menu.
    -Then click start button to download and install.
    Hope this helps.
    Waiting your comments.
    Best wishes.
    ioktay
  • Ibrahim OKTAY
    After installing the Windows 7 64-bit drivers, you must also install another driver for your Delta 1010 PCI card which fix some bugs and problems.
    To do that click this link. And find the download link on the opened web page as you will see in the picture below. Download and install the driver.
    This may solve your problem. That is a fix for your audio driver.
    Hope this helps.
    ioktay
  • Ibrahim OKTAY
    Ibrahim OKTAY May 18, 2010
    Hi Sjkinguk,
    You did not answer my comments.
    Is your problem solved? If not waiting your comments.
    If solved the question seems open and pending, would you please accept the solution to close the issue.
    Thank you. Take care.
Is my e-mu 1820 work with my accer cpu
Simple answer: Yes, provided that you have a free PCI slot in your Acer. The E-MU 1010 PCI controller board is the only controller that will work with an 1820. The PCIe version will not work an one or both may be damaged if you try.
Do not expect to get anything close to good latency from an old computer. If your Acer is a P4 or an equivalent AMD or newer you should be fine.
Jan 22, 2013 | E-Mu 1820M Sound Card
Windows 7 64 bit Ultimate SP1. Nuendo 4.2.3. 32 bit version. Delta 1010 LT Sound card. Just out of the blue I started hearing slight crackle when playing back videos, wav files etc etc. It seems to do...
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
Sep 25, 2011 | M-Audio Delta 1010 Sound Card
Sound drives free download now
Drivers for that sound card can be downloaded from M-Audio's support site linked below.
http://www.m-audio.com/index.php?do=support&tab=driver
Choose Delta Series Card>Delta 1010>Select OS and you should be able to download the drivers.
Robert from Blitware
Jun 17, 2010 | M-Audio Delta 1010 PCI CARD Sound Editing...
Crackly sound on the P5NSLI motherboard
check for faulty RCA wire or Stereo jack, If you get that buzzing sounds 95% of the time its a faulty rca wire or 3.5" stereo jack hop this works
Mar 30, 2009 | ASUS P5NSLI (0610839134670) Motherboard
Audio Problem on Soyo mother board
remove & reinstall driver of your sound
Sep 03, 2008 | Soyo SY-5SSM Motherboard
Audio problem
can u give me the model no of *********** bord
Sep 01, 2008 | Soyo SY-5SSM Motherboard
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Jun 17, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Dec 31, 2007 | M-Audio Delta 1010 Sound Card
M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
102 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
