Question about Dyson DC25 All Floors Bagless Upright Vacuum
After running for afew minutes it shuts off ??
After running for about 4 min. the unit will shut down and not re-start until it cools down.
  • 20 Answers
Filters plugged. possible unit plugged at floor inlet also.
Posted on May 06, 2010
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka maxima heats up and shuts down after 10-15 minutes use??
sounds like you have a clog some where or need to replace your filters. your machine is tripping the thermal switch thats why it only runs for 15 min
Apr 02, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
May 21, 2011 | Hoover U5753-900 WindTunnel Bagless...
My vacuum is shutting itself off
Thats a tricky one. It could be the internal switch or it could also be a thermister. It's a very small thermastat inside if the unit that tells if the unit is running to hot and will shut off. Once it cools down it will run until it heats up again. You might want to have a repair shop look at it. One with free estimates. Good luck.. save $$$
Nov 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
Nutone central vacuum shuts off after a few minutes running then will restart after motor cools down I cheked motor and vent ports blown out all clean
Sounds like you have an overtemp switch that is tripping and shutting your motor off. Many motors use what they call a 'snap switch" ( looks like a small disk with two wires on it ) to sense motor temp and if that trips, then it will temporarily disable power to the motor until it cools down enough to allow power to be reapplied. If you are sure everything is clean and your motor can rotate freely ( if there is a restriction that limits motor rotation, more current is drawn to drive the motor thru that restriction ..which in turn will cause excessive heat build up and the temp switch to trip) ... Hope that helps!
Aug 13, 2008 | Vacuums
Dyson DC25 All Floors Bagless Upright Vacuum Logo
184 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
