Question about Casio TV-850TR 2.3 in. Handheld Television
Reception from an antenna
Now that you can't get reception from an antenna how to I watch it?
    Sergeant:
  • 418 Answers
Get a digital converter box. Ha! Ha!
Posted on May 06, 2010
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
How to eliminate the static in reception? When I touch or hold antenna it's clear; but can't do that all day!
what was the swr reading of the antenna ?
https://www.youtube.com/watch?v=YwFPKIjweP8
Aug 13, 2015 | Radio Communications
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
There is a weak reception
Get an inexpensive digital antenna, around $20. K-mart, Wal-mart, Target etc.You'll be amazed at the diference!
Aug 13, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
One channel on LCD not clear picture help!
this is a problem with the reception in your area. It should be resolved with an adjustment of your antenna to a location of clear reception.Ask someone in the house watch the television while the antenna is being adjusted for best reception and set the antenna. If you have cable, you must contact the cable company and ask them if they have a resolution to the reception problem. Hope this helps you with your problem.
Apr 25, 2009 | Insignia LCDTV26 26 in. Television
I need to improve TV reception through PC.I have a K World DA plug for the aerial. What do I need
Hello and Welcome to FixYa!
Your situation calls for the purchase of an amplified antenna. It is a regular antenna that uses an AC adapter to boost its reception clairity. A good brand of amplified antenna is Terk, and should not set you back more then 60 bucks at the most. There is also cheaper amplified antennas out there but do some research first as its absolutely true on the saying, you get what you paid for!
You might want to read this guide before purchase:
http://www.hdtvantennalabs.com/terk.php
Happy TV Watching!
Aug 25, 2008 | HP Computers & Internet
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
Casio TV-850TR 2.3 in. Handheld Television Logo
91 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
