Question about Kenmore 62622 Microwave Oven
MY MICROWAVE OVEN CONTROL PANEL KEEPS RINGING AND HAS SE ON THE WINDOW PANEL
  • Kenmore Master
  • 9,098 Answers
SE error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 06, 2010
What does it mean to have SE on control panel
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
Mar 12, 2016 | Samsung SMH1713B Microwave Oven
What does SE mean on Sears microwave oven
I believe that means you have a shorted keyboard. You will have to replace the keyboard/control console assembly.
Oct 16, 2014 | Kenmore 62622 Microwave Oven
How to fix SE in the control panel of microwave
Remove power and clean the inside while checking if there are food particles on the inside or in the Wave-guides- the portion where the Magnetron is fitted. Also remove the main cover and clean the areas of the Magnetron , check for loose joints,Finally check if the main capacitor is faulty. Other wise you will need a check on the main board, and also the Magnetron for leakage.
Sep 03, 2014 | Samsung SMH9187 Microwave Oven
I HAVE A SAMSUNG MICROWAVE MODEL SMH8165ST KEEPS BEEPING SE
"SE" error on a Samsung made microwave means you have a shorting membrane keypad.
This is a pretty simple DIY repair.
You would need part number DE94-01806C which you can get for about $68 from the Pros here, our favorite supplier.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then unplug the keypad strip and move your board into the new frame. Be careful, because the display is made of glass.
Some connectors on the relays have a lock:
Jan 29, 2013 | Samsung SMH9187ST Microwave Oven
What is the symbol --se-- on a amana serial number1000001gt radarange microwave oven mean
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 16, 2013 | Amana Radarange Microwave Oven
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
May 02, 2012 | Samsung SMH9187ST Microwave Oven
Shows a 5E error code. Can you help?
SE means you have a shorted membrane keypad.
Actually the best overall solution to this problem is usually to order a new controller assembly (control box) and install it yourself. It's pretty simple.
We have a similar service manual and have uploaded it to our site here to help you.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears parts direct Web site here.
At Web site , they have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Apr 23, 2011 | Samsung SMH9187 Microwave Oven
My display is showing ---SE--- and the buttons are not working?
"SE" error on a Samsung microwave oven means you have a shorted membrane keypad.
I can't find any service data on it.
From review site listings, it looks like it retailed for about $80 at Kmart a few years back.
I'm guessing it's now fodder for the recyclers.
Good luck.
Dec 31, 2010 | Samsung MU3050 Microwave Oven
Not working i see a code (se)
On some models, you can replace just the membrane keypad, which is very inexpensive, but difficult.
On other models, you can replace the plastic control panel frame, which comes with a new keypad already installed.
If I knew your full model number, I could give you the part numbers, prices, and links you need.
Feel free to contact me directly (and include your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 30, 2010 | Jenn-Air JMV8208BAS Microwave Oven
Kenmore 62622 Microwave Oven Logo
161 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
