Question about ViewSonic VX1935wm LCD Monitor
VX1935wm using analog input has image shifted ~3 in left
VX1935wm using analog input has image shifted ~3 inches to the left (can't see the left 3 inches). Must be the monitor because this happens no matter what pc it's hooked up to. Happened all of a sudden...no driver or other updates have been recently installed. Other monitors work fine with all PCs that I've tried with this failing monitor. thanks...
  • Bud Martin
    Bud Martin May 11, 2010
    Did you try going to the on screen menu and set it to factory reset/setting?
  • 109 Answers
Try to Google for service menu...then adjust from there,,
Posted on May 09, 2010
How can i hook up a nintendo wii to my 50 inch sanyo plasma t.v and keep my digital cable hooked up at the same time?
I just took a look at the back of your TV and I know exactly what your problem is. First, you need to understand that digital cable is not HD cable necessarily and standard digital cable has analog outputs. Now, since you're concern is about not being able to keep your Wii connected to your TV without disconnecting your cable box, what you are telling me is that with the numerous numbers of input jacks on the back of your set (and the fact that the Wii comes standard with a red/white/yellow Analog Composite cable) you are using the only set of Analog Composite inputs (that also includes the S-Composite input) on your television set to connect your devices. Now, if you actually have an HD box, then you are not using the correct connections and cables and your beautiful 1080p Resolution High Definition television is displaying everything on cable at 480i Resolution, Standard Definition, even the HD channels. Analog connections are incapable of displaying in HD.
Now, I don't know about you, but when I put down my chunk of change and upgraded to HD, I wanted to make darn well sure that I didn't spend all that money to watch it in SD. Of course, that's tongue and cheek because I know you wanted the same thing and I'm going to walk you through the process of solving your problem and getting you the best picture possible out of your TV.
So the first order of business is to make sure that you have an HD box and if you don't you need to contact your cable provider and swap it out. Next you need to get yourself an HDMI cable for about $3. DO NOT waste your money on one in a store and do not believe any salesperson that tells you that the expensive ones are better than the cheap ones. They aren't and this is the biggest lie in consumer electronics perpetrated primarily by Monster Cable. Order it from Monoprice, as they are the best and cheapest. 6 feet is the standard.
http://www.monoprice.com/products/search.asp?keyword=hdmi+cable&x=0&y=0
An HDMI cable is one cable and all you need to do to connect it is put one end in the HDMI 1 input on the back of your TV and the other end into the cable box. It handles both the audio and video signals and your HD cable box should automatically detect it for video and audio. If by chance it doesn't detect the audio, go into the settings menu of the cable box and choose the audio sub-menu and set it to HDMI-out (these options might be under the heading "digital audio").
You'll also want to go into the video settings of your HD cable box and set the output resolution to only display one resolution (it will probably have several selected by default). Choose 720p or 1080i (your preference) as these are the only HD formats cable television broadcasts in. I have mine set to 1080i and the reason you do this is because not all channels are in the same resolution on digital and HD cable and what will happen is that your TV will have to reset its resolution every time you change channels and the resolutions change. This transition can take up to 30 seconds as you're sitting there staring at a black screen. By setting the resolution on your HD cable box to display only one of the HD resolutions, your HD box will simply upconvert the other resolutions automatically. I say choose between 1080i or 720p because not all cable providers broadcast in 1080i, using 720p exclusively so the 1080i setting is unnecessary.
Last thing about your display regarding HD cable: Your HD cable will display television programs in both the 4:3 (standard) and 16:9 (widescreen) formats. When the program is in 4:3, the image will not fill the entire display showing black bars on the left and right sides of the image. Plasma TV's are susceptible to what is called screen burn-in (or image retention or as Sanyo calls it, "after-image"). What this means is that if static images stay on the screen for too long, it will actually stay in the screen after you've changed the channel and it can be permanent and this damage is NOT covered by your manufacturer's warranty. Your TV has a feature to fix this (refer to your manual, near the end) if the "burn-in" is not too extreme, however the best way to avoid screen burn-in is to prevent from happening to begin with. While the TV is displaying a 4:3 program, the point where the image ends and the black bars (lack of image, technically) will burn-in. To avoid screen burn-in, you should change the format of the image to fill the screen via either your cable box (your cable remote will have either a Zoom key or a Picture Size key) or on the TV by pressing the PIX key on the lower left hand corner of your TV remote until you get the desired image. Use the option that zooms in, and not the option that stretches and distort the image. HDMI Cable captainhawk1_8.jpg
So now you have the Analog Composite inputs free to use for your Wii, however, I'm going to give you another alternative that will increase the quality of your picture when using your Wii. The Wii has the ability to use Component Video Cables for its video signal sent to your TV. Your TV has two Component Video Input Jacks (VIDEO 2 and VIDEO 3) and the are indicated by their red, blue, and green color. You'll still need to use the analog red and white audio connections when using the Component Video inputs but for this setup, they are right to the left of them.
Now, of course, Nintendo does make this cable but their's costs $20 and again, you can go right over to Monoprice when you get your HDMI cable and get it for less than $3 and like the Nintendo cable, it comes with the audio cables integrated. I have this cable myself and it makes an amazing difference.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083007&p_id=5689&seq=1&format=2
Your TV will automatically detect both the HDMI connection and the Component Video connection so it will not require any setting up.
For more information refer to your manual, here:
http://us.sanyo.com/dynamic/product/Downloads/DP50747_Manual-31187309.pdf
May 06, 2011 | Sanyo DP50747 50 in. Plasma TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Screen shift for Panasonic TH37PD25
This is an issue you must take up with your new cable provider.
Apr 08, 2017 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Convergence problem? Blue shifted to the left, red/green are okay
If your model number is the PT53WX53 its a rear projection CRT television not a DLP. The PT53WS53 uses two STK392-110 convergence ICs. If you verify the model number of your set I can assist you.
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Horizontal view on screen will not re-center
You want to locate Position or Horiz Position from the Menu screen. Press menu first then Up or Down to select the item you want then Left or Right, I can't be more specific as all monitors are different - but there isn't a single button to center. You could also try the different input settings (Analog, Digital, etc) if the Autoselect isn't working properly.
Dec 12, 2008 | Computers & Internet
Excessive Dropouts
I had the same problem with my VCR. The problem is not a dirty head. I was connecting the VCR to the A/V input of those new TVs with the digital tuners. I got rid of the problem by connecting the coaxial (analog Channel 3 or 4) output of the VCR to the Antenna input of the TV and tune to plain old analog channel 3 or 4. That way you apparently avoid the digital circuits and those blasted dropouts; Now the VCR plays perfectly on my new 42-inch TV..
Feb 28, 2008 | Samsung SV5000W VHS VCR
Image has shifted to the left
You need to contact a technician who has the software jig to fix your problem.....The part number is TNPX25JIG and is no longer
available...........Good Luck.
Jan 25, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
ViewSonic VX1935wm LCD Monitor Logo
93 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
