Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Error! video index save overdue for main image
Error! video index save overdue for main image partition. system operation may fail, image data may be lost.
note error number=9999
2 Suggested Answers
SOURCE: Error! Video index save overdue
use ur brain
Posted on Nov 17, 2010
Updated tool for restore Windows hard drive data
If the hard drive will not boot, use the Windows installation disc to repair the operating system. If that fails, install a fresh drive and install the operating system. Then attach the old drive to restore your data.
If you accidentally erased your hard drive data, you may need to purchase recovery software, or send it to a company to recover your files.
May 05, 2014 | Computers & Internet
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
Error number = 6019 Get this message which
Its hard drive fail. on a wright error cannot read the file. hard drive will need replacing or re formatting can happen with power cuts so would check the cpu aswell.
Jun 20, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
Error number = 6019 Get this message which won't
its a hard drive fault. change thye hard drives. and instal new firmwear. hard drive have to be formated to FAT32. download softwear from dedicated and the 3 files to the new hard drive you are going to use as master first file is Boot and other two files no note pad or think its dv softwear. put the hard drive in cctv, then turn on should boot up and the add the files to its system from the zip file. after it has finished it will set up slave drive. down load the manual as well so you can rest the system for how many day to record for and save video for how meany days etc.
Mar 14, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
How do i master reset my acer 5220. my accer 5220 wont start up, it started playing up about a week ago and i think it had a bug but now wont load past the windows screen. i have tried loading in all the...
If the system can not boot, you can restore it from the WinPE environment. The system starts from the hidden partition on the hard drive. To begin the restoration, press Alt + F10 (PC Tower) or F10 (laptop) to boot the PC and when the Acer logo appears. This will start the system from the hidden partition the hard drive and you access its main page. The restoration will be on partition C:. The partition D: (ACERDATA) will not be formatted, and therefore documents will not be deleted but it is always prudent to think about making a backup of your most important documents in case!
Note: You will be asked to enter the password before the System Restore starts. If you enter the wrong password three times, the computer will restart into the operating system.
You must enter the password to access the main page of the hidden partition. The main page of the hidden partition provides three options to restore the system:
1 - Restore the system to factory default settings: Select this option and then enter the password. The utility will restore the system from the image of the factory default settings on the hidden partition on the hard drive. When prompted, confirm the system restore. A message will warn you that you will lose all data on the disc. The utility then restores the system to its original state.
2 - Restore the system from backup user: Select this option and then enter the password. The utility restores the system from the image of the user on the second partition on the hard disk. When prompted, confirm the system restore. A message will warn you that you will lose all data on the partition. The utility then restores the system to safeguard user the most recent.
3 - Restore the system from the CD / DVD: When this option is selected, insert the first disc of the backup in the optical drive. Confirm System Restore when prompted. A message will warn you that you will lose all data on the partition. The utility will restore the system from the backup image on CD / DVD. Insert the other disks when prompted.
Note: If you are trying to restore the system to its factory default settings stored on CDs / DVDs, Acer eRecovery Management prompts you to insert disc 2 to start.
Good Luck
Nov 01, 2009 | Acer Extensa 4620 Notebook
Recovery partitions
You' want to set aside some space where to create these backups, they are generally 25% of the total drive space.
the assumption is that there is no data on the drive to save. During the install it will ask where you want to install windows, if there are existing partitions delete them all. Then create one partition and specify it to be 75% of the drive (or whatever you prefer). Leave the rest unpartitioned.
Select the partition you created to install windows on.
Once you have installed windows and all the drivers etc, format the rest of the drive in Disk management (part of Computer management in Control Panel). Finally install your favourite software to create backup restore images, and set it to save on the partition you created.
NOTE: you will still need to back up on some external media, if the drive fails all data will be lost.
Hope this helps
Feb 01, 2009 | Microsoft Windows XP Professional
Televison & Video Logo
321 people viewed this question
Top Dedicated Micros Televison & Video Experts
CoppellTVRepair.com
electracon
 Russ Hill
Russ Hill
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
