Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Seems to have no power. No lights are on the panel
I started the machine last night. About 2 minutes into the cycle I opened the machine to put another glass in. That is when the problem started. It is about 1 month old. I suppose the wiring could have come loose. I have checked the breakers. Any thoughts before I pull it out to check the wiring. Thank you
  • 10,515 Answers
There could be Few Possibilities :-
1. Loose Wiring.
2. On Few Dishwasher's, you have a Fuse on the Control Board. If that Fuse goes Bad or Crazy, the machine would end up Dead.
3. Control Board
Other than this, i have never seen any other Major Problem. I am buying the information that you Opened the Machine and it goes Dead. There is no Error Message.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 06, 2010
Cannot unlock door
Try first putting the control on 0 , then unplugging power cord for ten minutes, then plugging it bac.
If this does not work try restarting the cycle at any point and leave the cycle to complete, then you try openoing the door.
Sep 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Descale the saeco vienna not digital super aotomatic machine.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water. Now open the knob and run the whole tank at one time to rinse.
5. Refill water tank with fresh water and place it back on the machine.
Done
Dec 24, 2009 | Saeco Vienna Espresso Machine
Hoover H130E 'Superwash' and start light flashing after cycle....
You might try unplugging the power cord for 5 minutes, then restore power again. Try the machine again--if still has problems (beat son severely), you may have to replace the control unit.
Aug 11, 2009 | Washing Machines
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
51 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
