Question about Kenmore 63942 Dryer
Dryer door latch installment
I have a dryer latch kit to install on my dryer door. Please show me how
  • MLIowa Jul 06, 2008
    I need a door latch kit for my Kenmore Heavy Duty dryer (1978 model).
  • scotland1957 May 16, 2009
    Is it the same for an indesit dryer, just prise of the door catch with a screwdriver? Thank you
  • 943 Answers
Thanks for the question The door latch assy is only 2 small pieces a striker &a catch Just pry off with a blade screw driver and then pusn in the new one thanks for the question The appliance doc
Posted on Sep 11, 2008
Kenmore electric dryer model number 86860100
door latch kit 279570. repairclinic.com has picture of it
Oct 13, 2013 | Dryers
Whirlpool WED6200SW1 Door not shutting properly, please help.
You will need to replace the door latch and catch assembly. CLICK HERE for the updated kit that will make your door close easier. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool WED6200S Electric Dryer
Door will not stay shut...........simply pops open after 10 or 15 seconds. No visible damage. No debris along the door pathway. Perhaps a new plastic latch. The old one looks fine.
You just need to replace the catch and the strike it is easy to install.
Detailed Viewhttp://www.easyapplianceparts.com/PartInfo.aspx?Inventory=334230&SourceCode=6 EAP334230: Door Catch Kit This dryer door latch kit comes with one plastic door latch, and one metal door strike.
Easy Part #: EAP334230 Compare At: $4.75 Your Price: $3.96 You save: $.79 Availability: In Stock 334230_1_m.jpg
Above example contains part: EAP334230.
Click image to see large version
Model number:
Part description in this model:
Part location: #
Series number: -->
334230_1_s.jpg 334230_2_s.jpg 334230_3_s.jpg function KeyPress(e) { if(e.keyCode == '13') { if(document.getElementById('_ctl0_menu1_SearchNum').value != "") { document.getElementById('_ctl0_menu1_SearchButton').focus(); } else { e.returnValue=false; //required for IE if(e.preventDefault) { e.preventDefault(); } // required for gecko } } } '); //-->
Dec 03, 2010 | Kenmore 62602 Electric Dryer
I have ordered a door latch assembly for my cabrio dryer wed6400S. How do I install that latch? Do I take the door apart by unscrewing or just pull that latch out. It is broken and just wiggles. Thanks
open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
latch assembly:
http://cgi.ebay.com/Dryer-Door-Latch-Catch-279570-fits-Whirlpool-/330503664154?pt=LH_DefaultDomain_0&hash=item4cf38db21a
Dec 02, 2010 | Whirlpool WED6400S Electric Dryer
The internal fitting for the door catch has broken. What is the part called and are there instructions for replacing it?
Hi Gary, It is called a door latch...
Try this website Gary, they will probably be able to help you get the part and install it.
They also have a live chat assistant that can answer your questions 24/7
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Door-Latch-Kits/index.aspx
Or this one, they also have a chat assistant that may be able to help you.
Good Luck,
I hope this helps
Oct 17, 2009 | Hotpoint TFA34 Electric Dryer
The door on my tumble drier wont stay shut. The drier runs if I hold it shut. I have checked the peg and the door and cannot see anything wrong with them?
Buy a new door latch kit aprox $5.00. When you install these parts make sure the latch and the peg are lined up in the same direction
Aug 04, 2009 | Hotpoint Dryers
I have a maytag ensignia, the dryer does not work on sensor dry
im not just sure about what your saying.but if the door latch is broken on the door or in the body of the dryer you need a door latch kit
Jan 01, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 63942 Dryer Logo
838 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
