Question about Acer 22" X223w LCD Monitor
Moved monitor and when I recionected monitor I have a green tint. How do I adjust the color back?
  • 11,361 Answers
Please check all the pins on both ends of the VGA connector, more likely to have bent pins or not seated properly.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 06, 2010
Testimonial: "Right the first time, Found Pin Mutilated by this not so tech savvy user, with new VGA cable back to normal. Thank You So much."
Monitor went yellow. can still see program but the whole screen is yellow looking...
Posted on Aug 25, 2010
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
The screen has a dark green tint and cannot be adjusted. More specifically, the green section of the RGB setting on the monitor can't be changed (the G setting is permanently gray and I cannot move to that...
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
Apr 02, 2011 | Sony SDM-HS73P 17" LCD Monitor
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Jun 12, 2009 | Panasonic TH-42PX60U Television
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Mag monitor dx17t tint adjust
adjust color and tint by pressing buttons on your monitor
Feb 09, 2008 | Computers & Internet
Monitor green where it should be black
resolder some components on the boards inside your monitor especially on the CRT neck board.
check also your monitor cable connection to the System unit.
also check if your video card was fully intact on the board.
Nov 28, 2007 | Acer AC 713 17" CRT Monitor
Acer 22" X223w LCD Monitor Logo
246 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
