Question about Andis 29745 Clipper Headliner Hair Trimmer
How to replace cam drive on andis super 2 speed
Please let me know how to replace the cam drive on andis super 2 speed
    New Friend:
Why is there no youtube video of this process? For the life of me I cannot figure out how to release the two long black clips at the front and back of the motor frame. :(
Posted on Feb 27, 2016
  • 193 Answers
Ok you need to take the upper cassing off, remove the hinge assembly and the circuit board now the motor unit should come away from the lower cassing.
remove the clips holding the carbon brushes in place beware there are springs behind these clips, remove the two long black clips holding the front and rear motor frames to the field coil and then pull apart. This will allow access to the armature and then simply unscrew the drive cam.
Totaly dismantle all the parts of your Andis AGC clipper.
Posted on Sep 27, 2010
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
Clipper will only work on slow speed could it be circuit board
Please call the andis customer service dept at 1-800-558-9441 to discuss repair for this unit.
May 24, 2014 | Andis AGC Super 22360 Hair Trimmer
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
Single speed
Maintenance must be done and clean the engine
Jan 25, 2014 | Andis Agc Super 2-speed Clipper...
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Sep 15, 2013 | Andis Agc Super 2-speed Clipper...
Andis Clippers not locking
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
May 01, 2013 | Andis Dog Clippers - AGP Super 2-Speed...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Andis super Agr+ / Andis Agc super maintenance
There is little needed most componets such as the motor and carbon brushes are fairly complicated and should be checked when the units are serviced.
Keep an eye on the Blade Drive Assembly as with most clippers they wear on the sides causing cutting problems such as lines in cut fur and snagging blades, alternatively send them, to our Clipper Repair department.
Mar 01, 2010 | Andis AGC Super 22360 Hair Trimmer
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
How do i replacethe drive bearing in the andis agc super2 model?
For a more clear explanation please call the Andis customer service department at 1-800-558-9441 and ask for Jane.
Thank you,
Aug 21, 2008 | Andis 04710 Beard Trimmer
Andis 29745 Clipper Headliner Hair Trimmer Logo
305 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
