Question about Ryobi Backpack Blower 25.4cc
Blower will only run on full choke ryobi ry08578
    Problem Solver:
  • 5 Answers
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
Posted on May 06, 2010
Ryobi 80930 washer. Got it last year has only been used a few times. Inside during winter fuel was drained,only runs on full choke,cleaned the carb,spark plug, new fuel and had no affect. Any advice?
on runs on full choke indicates a blocked main jet or lack of fuel
I would pull the carby and replace the diaphragms or make sure that the gasket is on the right side of the diaphragms
if you used e- fuel mix then the diaphragms will be damaged
check around before buying parts as a new carby is now cheaper than parts to fix it
Jun 01, 2016 | Ryobi Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
How do i get to the carb on the ryobi ry08578
Goto the following website, click on parts locator and enter your model number. Form there you can get a parts breakdown for your blower. Figure "B" has the carburetor info.
Service Support
Dec 28, 2014 | Ryobi Backpack Blower 25.4cc
I have a new Ryobi RY08420 new out of the box. It starts fine and seems to idle fine. When I go full power, it is almost like the choke lever vibrates further back and causes it to bog down. If I adju
Running too lean at full throttle. Yes you need enrich the high speed mixture a little but make sure the blower has warmed up first that if the carburetor is adjustable.
Nov 21, 2014 | Ryobi Garden
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need a manual
The best I can do for you is hook you up with Ryobi to order their Operator's manual. Listed below is a link that will take you to Ryobi's diagrams and parts for this model blower...you will find the Operator's Manual at the bottom of the list in Figure A...you can then order it from Ryobi.
You are going to have to tunnel through to get to it, I will walk you through: Click this link first- http://www.ryobitools.com/support/parts_batteries
Then click on the tab that reads:
Then click on: Repair Parts Catalog, the HCPI, a new window will open, click on the I Agree tab, the catalog itself will open, enter your model number (RY08578), once your model comes up, click on Figure A, a new window will open showing a parts diagram and the list of parts underneath the diagram, scroll to the bottom of that list and you will see the Operator Manual listed, click on Add to cart and order...easy peasy.
Jan 16, 2010 | Ryobi Backpack Blower 25.4cc
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower 25.4cc Logo
1,617 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
