Question about Carrier 38CKC036 Air Conditioner
No heating only flashes - Carrier 38CKC036 Air Conditioner
  • 2 more comments
  • rickpakuza May 06, 2010
    Hi I have a carrier 42G250HP-1 air conditioner. everyting is running except heating I get only green flashes. ( three times duration )
    Hi Ladyybug68,The out door unit is a Carrier 38G250HP-1 indoor 42G250HP-1
  • rickpakuza May 11, 2010
    HI Silverdragon, The flashes are not electrical, they are the green LSD light on the internal unit.The cooling works O.K. Regards Rick.
  • 3,247 Answers
Have you checked if the room temperature is higher than what you have set on the controller (thermostat) otherwise it may not turn on. Do you have to press heat or cool button on the controller to switch from heating to cooling or does it change automatically depending on the temperature setting and the room temperature.
Try to turn off the mains power and start with the cooling cycle. If the problem persists with cooling and not heating then check if atleast the fan is running. If this is ok then confirm if the compressor (outside) turns on. Sometimes due to lack of sufficient refrigerant the compressor may not cut in. (leak test will confirm this).
Good luck.
Posted on May 11, 2010
  • Sam May 12, 2010
    Sorry the fixya.com system does not allow experts to view the full problem comments when responding to customers. This means I missed all the details that followed your problem comment yesterday in response to other experts.
    I did not know that you had already provided the full model numbers of your units and a detailed description of the problem you are having with heating function. Please ignore my yesterday's comments. (11th May).
    I realise your unit might be described in this document
    http://www.ahi-carrier.co.nz/uploads/pdf...
    Please confirm if this is correct. (look at the cover page right hand side bottom where it gives the model numbers of your outdoor and indoor units).
    Do you operate in HEAT mode or AUTO Mode?
    Are the temperature settings within the recommended range for heating cycle? (see page 23).
    Please confirm if the LCD flashing is on the remote control unit or the main indoor unit?
    Check if the timer is not set which means you might not be operating in the Manual mode.
    Have you tried to turn off the mains power to both the units (indoor and outdoor) and turned back on after a few minutes?
    Please post your comment as clarification to my above questions.
    ---cmmiuser01.
  • rickpakuza May 13, 2010
    I have tried in manual and auto ,the LED is on the inside unit (unit on ) I thought three flashes represent a fault. It does not change over from cold to hot, my be change over valve is stuck.
    Apart from this the unit works fine.
  • 12,061 Answers
Ahi-carrier.ae/download.asp?frm=docs/pd_107.pdf
This is a serious problem, But below is an application and servicing guide, this should sort you out,as to troubleshooting, and what to do. http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38-10sm.pdf
You need to call a professional, as I think you will agree after perusing the manuals, In any event the Service manual should help you track it down. Any electrical flashes are never good, and usually indicate a bad connection,one must be careful, as arcing and flashing can lead to fires. You must make the unit safe to work on it, please be careful.
    Guru:
  • 415 Answers
Hi Rick,
I will help you. Please offer the make and model of your unit. Also, need to know if anything is running. I look forward to hearing back from you.
Posted on May 06, 2010
  • 1 more comment
  • laura Newman May 06, 2010
    Please offer additional Mamke and Model #'s of your equipment to include "indoor" and "outdoor".
    Thanks. :-)
  • laura Newman May 07, 2010
    Thanks for that information Rick. I am in the process now of obtaining information specific to your unit(s).
  • laura Newman May 11, 2010
    Rick,
    It is with regret that I have been unsuccessful in locating information specific to your unit.
    I can only suggest turning off the circuit breaker(s) to your system for approx 10 minutes. Then turn them back on and try your heat again. I truly wish I could have found more information on your system so that I could better serve you.
    Very Respectfully,
    Laura
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Flashing clean and heat light?
Sounds like you might have lint build up. Clean out lint trap and remove the back and clean out all lint. The lint build up could be causing a over heating problem. And this is a fire hazard.
Aug 08, 2015 | Whirlpool Dishwashers
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
108 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
