Question about Fuji FinePix A400 Digital Camera
Yes, that's it, basically. You may need a three-wing screwdriver, and be careful not to damage the little "hinge" that locks the ribbon to the circuitboard.
Posted on May 10, 2010
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 04, 2012 | Computers & Internet
hope this helps
Sep 17, 2012 | Computers & Internet
If device shows an white LCD screen displays, you may first check and try to install a new
replacement LCD screen. Get a screw driver to unscrew the phone. Remove the LCD screen from the panel. Replace it with a new LCD screen and couple back the phone
But if the problem continues, then try to flash, restore or update the device
flash firmware.
But if the phone is under warranty, i will advice you to take it back to the NOKIA store. The phone will be replace or it will be repair for free.
Regards
Jul 06, 2011 | Nokia N70 Cellular Phone
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Jul 15, 2010 | LG TRAX Cellular Phone
May 31, 2010 | Nikon Coolpix L11 Digital Camera
Jul 04, 2009 | Nokia 7610
Nov 17, 2008 | Sony VAIO PCG-K35 Notebook
Oct 31, 2008 | Samsung Cameras
Mar 25, 2007 | Sanyo Xacti E6 Digital Camera
754 people viewed this question
