Question about Intertherm P3RA-060K Air Conditioner
My cooling and heat pump quit working and the fan outside does not come on. If you push in the contactor in the fan comes on and sounds like the compasator does to.
  • edward_hanna May 06, 2010
    Back in the winter the heat pump quit working so I used the heat strip. The temp has rizen so I turned the air on no go. The unit inside comes on but the unit outside does not neither does the contactor. I have 240 going to the out side unit and 26 volts on the power for the control board.
  • Brian Niten May 11, 2010
    If you set the thermostat inside low enough for the a/c to kick on does the indoor fan come on? Check the outside unit, is the contactor pulled in? Check these 2 things and let me know what you find.
  • 674 Answers
Check the voltage at the contactor where the 24 vac connects to the coil for the contactor so you can see if it is making it that far. It will be 2 smaller wires that are not connected to the 240 vac. Let me know if you have 24 vac there. The thermostat will have to be calling for air for the 24 vac to be present. let me know what you find.
Posted on May 06, 2010
Why does lenox heat pump not heat in normal heat mode?
The thermostat is not a heat pump thermostat or it is not wired or set up correctly.
Feb 05, 2015 | Heating & Cooling
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
We live in southwest Florida. Our HVAC system consists of a air conditioning system with heating coils when it is cool. Yesterday morning we tried the heat nothing come on. Later in the day I tried the air...
Hello. Sounds like you do have power. That spring loaded plastic switch is a 24v contactor. It pulls in when energized. If you push it in manually everything shoud run normal. Ck your 24v transformer. On one side (feed) you should have 115v or 220v depending on what kind of transformer is used likely (115v). Coming out of the transformer you should have 24v. If not you need a new transformer. You will need a mutimeter for this. If you know you have power where the wires are connected then you know how to use a mutimeter. Only way to know for sure outside of manually pushing in the contactor. Good luck. Be sure to kill the power before making repairs.
Jan 15, 2011 | Heating & Cooling
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Goodman AC Unit with Heat Pump - Works great cooling when switched to heat the outside unit does not come on - inside comes on and uses emergency heat? What can I check? I first checked the contactor and...
Because the outdoor unit works in cooling, it sounds as though the contactor and other components outside are working correctly. The problem sounds as though it might be somewhere in your thermostat. Has the thermostat been replaced recently? If so, make sure it was wired correctly. If not, check all of the connections and contact points in your thermostat. In order for your outdoor unit to run, you must have 24vac at your "C" Common and "Y" connections. You must have this in COOL mode. Now it has to be determined why you don't have it in HEAT mode. Definitely a thermostat issue.
Hope this helps and good luck! :-)
Mar 05, 2010 | Goodman CKL60AR60 Air Conditioner
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Ruud heat pump makes a clicking sound
Many thermostats have a setting to keep the fan running instead of cycling with the compressor. Check its settings.
Dec 21, 2008 | Ruud UBHC Air Conditioner
Intertherm P3RA-060K Air Conditioner Logo
196 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
