Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Shut down due to blocked ventilation
Shut down after a few minutes due to blocked ventilation
  • 160 Answers
Don't block the ventilation, make sure to clean the filters, and keep it cool.
Posted on May 06, 2010
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
My aspire one d257 will shut down automotically afte a few minutes
Try running it on a hard flat surface and see if it runs better. The shutting down could be due to the machine overheating due to poor airflow. Try cleaning the air vents around the case, make sure they are not dusty.
Apr 09, 2012 | Acer Aspire One D257 Netbook
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
The color seems to be fading. There is a dull yellowish tint to everything it plays.
The tint you are seenig is most likely the lcd panels developing thermal damage due to the projector being improperly shut down. The projector should always be shut down using the remote or the power button on top of the projector. OR if this projector is ceiling mounted it could have blocked ventilation or if used in a smoky environment it could be smoke stained.
Nov 16, 2010 | InFocus ScreenPlay 5000 Multimedia...
The oven is not work or better say works for little be and going off. could you please help or please let me know what telephone should I call?
Hi,Everything operates normally, but the oven shuts off after varying amounts of time. This could be a faulty magnetron, bad cooling fan (or just built up dust and grime block ventilation grilles), bad thermal protector, faulty controller, some other intermittent component, or bad connections.
  • If resetting it allows cooking to resume immediately, if even for a few seconds, I would not suspect the magnetron or thermal problem as no cool down time is required. It could be bad connections in the controller or elsewhere, a marginal door interlock switch, or a controller problem. Jiggle the door to see if this will cause it to shut off.
  • If the magnetron was overheating, you would not be able to resume cooking until it cooled and the thermal protector reset. If it just stopped working (i.e., the filament opened), everything would appear normal but there would be no heating. If the magnetron were shorting, there would likely be a loud hum associated with the periods where there was no heat.
  • If it is not possible to resume cooking for a few minutes indicating that something needs time to cool off, then the magnetron could be faulty but check for the obvious cooling problems first: blocked or dirty ventilation grill. Determine if the magnetron cooling fan is operating by listening for its sound or looking through the ventilation opening in the back of the oven. If it is not, there could be a broken or weak belt, gummed up or lack of lubrication, other mechanical problems, a bad motor, or bad connections.
  • Extremely high power line voltage may also result in overheating on a poorly designed or oven where the components are marginal.
  • Make sure the stirrer fan is turning normally. Should it gets stuck, some models may sense this and shut down/restart.
Hope it helped..
Thanks for using fixya....
Oct 20, 2010 | Ovens
I got lenovo y 410 its always overheating
Hi, Make the following check:
If you can open back cover, try to check and clean fan to ventilate or there's already available docking station with ventilation pact it can help.
You should not use a laptop on a soft surface such as a duvet or bed covering. The device needs to have free air intake and outlet to cool the processor. If you block the intake, which is probably under the machine, it will overheat and shut down. If you want to use it in bed put it on a hard surface such as a large book, so that the air intake cannot be blocked.
1. Boot your system in "safe mode" and check whether the problem persists. If so the problem is due to some freshly installed software, which you can of uninstalling. 2. If the shutdown happens when you are running on battery then check your power management software whether the battery is draining out rapidly. If problem is still there, then instead of trying your self, please consult your local lenovo technician / support centre.
Thank you!
May 17, 2010 | Lenovo 3000 Y410 Notebook
Model PJ556D will run for a few minutes and then shuts off. Once it cools down it will start back up, but shuts off again a few minutes later.
Hello, Greg.
The most common reasons are the temperature is too high or the ventilation holes are blocked.
Unplug the AC power cord, wait 5 or 10 minutes then turn back on.
There could be dust or the air filter needs to be changed.
Take the lamp cover off the bottom. It's possible that the screws holding the lamp are loose.
Hope this helps.
Apr 05, 2010 | ViewSonic PJ556D DLP Projector
Video cuts out after a period of operation.
Yes. Thermal shutdown is now commonly used instead of fuses to protect from overvoltage conditions. It possible that dust, animal hair, etc. is blocking the ventilation holes for the device. This sets depend only on convection for ventilation so it doesn't take much to cut the circulation down. You can try spraying through the ventilation holes with "canned air" to clear them out.
Do this with the set off and rotate the set, not the can, to get at all the holes. If that doesn't work, it will take a qualified technician to repair the problem.
Jan 09, 2010 | Insignia IS-LCDTV32 32 in. Television
Sony vaio system becomes hot and shutdowns
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Nov 22, 2009 | Sony VAIO VGN-CR510E/L Laptop
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
