Question about Adesso (CYBERTABLET12000) Graphic Tablet
Doesn't work properly
Everytime I want to draw something for some odd reason it doesn't work properly. The mouse moves too fast making it hard to draw.
Please help
I cant unlock my mouse sensor..
If you can't unlock your mouse sensor then follow these instructions down below:
To make your mouse MOVE first you must
1.Put your mouse usb in your laptop in the usb holders
2.After you done, something should pop up a few seconds later near the bottom right hand side, saying usb mouse connected.
Try moving your mouse now.
if doesn't work:
go in the control panel ( you can find that in your window by pressing the window button on your key bored)
3.Then there should be a topic named " Hardware and sound" click the first topic called " view devices and printers"
4. After you clicked that there should be on the top on the page "Devices" and the bottom should be printers and faxes.
5 then you can double click the device to look if right one. DONE!
I hoped this worked! ^-^
Sep 29, 2012 | Acer Aspire 5102WLMi Notebook
My cursor on my HP doesn't work. don't want to use a mouse.
i'm sure that there's a button to lock the trackpad,it's near the panel.you need to press it once again to turn the panel on
I think it's right above the trackpad
or look on your laptops keyboard for a picture like trackpad press it with the function Fn button at the same time
or it should be the hardware
the trackpad cable maybe doesn't installed properly,not locked or something
Aug 20, 2012 | Computers & Internet
Everytime my notebook gets started up it freezes about 45 seconds later
It seems alot of people have had similar issues with these PC's.
Sounds like it could be a virus or registry error. But could also be a hardware error. Does the machine run hot? If so, try cleaning the vents and running it on a hard, flat surface. If that doesn't work I would try running an anti virus and/or anti malware program (in safe mode if that's on option) If that doesn't find anything, then you could try reinstalling the O/S.
Is there a recovery partition on the hard drive?
If none of the above works, then it is probably a hardware issue, hard drive or RAM error, something like that.
Mar 16, 2012 | Sylvania Computers & Internet
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
MY BELKIN WIRELESS MOUSE MODEL #:F8E899-BNDL & S/N: 06C 000196, DOESN'T SEEM TO MOVE THE POINTER AROUND ON CERTAIN SURFACES PARTICULARLY FLAT, HARD SURFACES. iT SEEMS TO WORK BETTER ON JEANS....
Delete the driver you have now and when you plug back the unit it it will install driver and look for a updated driver you really can just take it out of usb port and put it back in and it will do that
May 04, 2017 | Belkin Wireless Desktop 130
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
When power on my computer averatec, screen show lines and move the mouse this line, move with the mouse, i think the problems is the grafic card nvidia P419
You are prolly correct. Try making sure you video cable isnt loose first then update windows to make sure you have the correct driver.If it doesn't work then buy a cheap card.
May 08, 2011 | Computers & Internet
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Open Questions:
Adesso (CYBERTABLET12000) Graphic Tablet Logo
Top Adesso Computers & Internet Experts
Alun Cox
Pcm2048
Chris Benedict
Level 1 Expert
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
