Question about RCA RT2250 System
Only VCR2 sound working, no video
I am trying to hook up my dvd player and cable to the sound system. The only input that will work is the VCR2 in the front. Also, I cannot get the video to feed through the system... only the sound will work. I have the s-video cable going from the out to the tv and then the red, yellow, and white cords going in to the sound system. Please help. Thanks!
  • madelinedw May 06, 2010
    Thanks! I would have tried that, but the tv is actually a tv monitor and doesn't have the yellow plugin. It does have the s-video cable though.
  • 55 Answers
If you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
Posted on May 06, 2010
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
I can't seem to hook up my Insignia T.V. and my dvd player up
The way to hook up the dvd player to the television to to put a cable into the output signal section of the dvd player( Ther may be many different ways to hook-up the signal s-video and component video, regular video. You must pick one of these output signal sources to put into the input section of your television by matching them up i.e s-video out to s-video input compnent video output to component video input, regular video out to regular video input. For each of these video hook-ups there will also be a set of two sound cables. Look on the back of your television for the signal input section and hook up the video cables and the sound cables to your selected input. You should do this with both units turned off in order not to damage the circuits by shorting them on cable insertions ofr causing heavy feedback in the circuits. One this connection is complete. Trun on the television first and select the TV's signal source . By pressing the input button and using the up and down arrows to find the correct selection. By matching up all three sources you now should have the correct signal path. Turn your DVD and test the controls. try using the volume control and use you dvd to to play,ff, or stop the dvd.If all this works then you have done the set up correctly and can now enjoy your dvd's on the television Hope this helps you with your problem..
Mar 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
"No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
RCA RT2250 System Logo
67 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
