Question about Juki TL-98Q
It sounds like in bobbin is not hitting the needle the right way it will so good 15 to 20 inutes then it will skip stitches i was told the timming was not right
    Problem Solver:
  • 15 Answers
The bobbin should not be hit by the needle (sorry but your question is confusing).
If the timing is not right, it will not sew properly. Take it in to be timed; the machine sounds like it is in need of a service procedure anyway. It will come back running like new.
Posted on May 29, 2010
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Oct 21, 2016 | PfaFF Sewing Machines
Skips stitches
I had/have the same problem...the gal at Joann's told me that it is USUALLY related to the needle being wrong for the fabric, an old needle, pulling as you sew, etc. Tweak everything possible, use a scrap fabric, keep resewing til machine behaves and then go to your real fabric. I always sew now with a scrap I test before doing something on the real piece. Also I was having bunching with my UNDERSIDE and assumed it was the bobbin thread. She told me the underside problems are from the top thread, not the bobbin thread..so she showed me how I was slightly threading wrong. I have a Singer Curvy and love it, but it is finicky when default settings are changed with stitch, width, length not matching the recommended settings. Good luck!
Oct 06, 2014 | Singer 3270 Mechanical Sewing Machine
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
Singer Model 99 skips stitches
May 21, 2012 | Singer Sewing Machines
I have a Elna 6003. Recently I started having problems with the stitches skipping, and the machine was making a clicking sound. Now I have discovered that the needle is hitting inside the bobbin case and I...
skipping stitches can be the needle is damaged--flat side of needle goes to the back side of machine
normally when the needle is hitting the inside of the bobbin the timing is usually off, & can only be fixed by a sewing machine repair tech
Jan 31, 2012 | Elna Quilter's Dream 6003Q
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Juki TL-98Q Logo
70 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
