Question about SanDisk SDMX1 MP3 Player
After recording an interview, the file will not play back. It was around 15 minutes long... Every other VOCOR.wav file plays back except the one I need most. I try to select the file from the folder and it selects the next or previous file. Then I tried to just play the file before it and see if it would play and it didn't, it just skipped to the next recording. Please help
  • 31 Answers
The File Could Possibly Be to Large For The Device To Hold, Possibly Re-Do The Interveiw In Smaller Sections About 5 Minutes Long, Then Loop Them Together
Posted on May 06, 2010
I have a number of files on my digital recorder where I have recorded interviews. When I press play, it shows up the length of each interview and the countdown starts, but there is no sound, just a qu
Did any of the files ever playback with sound? You can record sounds, but that doesn't mean the recorder is picking them up. A bad connection, level control setting could be wrong.
Try to do another short recording. If you are using a microphone pull the jack out during recording and put it back in again. Then listen to the recording. If there is sound when the microphone is in and it goes when it is out, then there is a possibility that somehow you recorded the other stuff with no connection and that's why there is no sound. If there is no sound on the new recording at all, then you might have a faulty playback amplifier inside the device.
Apr 09, 2017 | Sony ICD-B200 Digital Voice Recorder
I recorded an interview on my Sony HDV camcorder, about 15 minutes in the screen goes blue but keeps playing. While in play mode, if I fast forward the interview pops back up but disappears as soon as I...
The heads are dirty and you are getting sufficient digital dropout to cause the blue screen. Try a cleaning tape. If that fails to correct hte problem, then the alignment needs to be checked by an authorized service center.
Dan
Sep 14, 2009 | Sony HVR-A1U Camcorder
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
Can I save a WAV file to MP3 format
There is a free program called Media Monkey - it will convert WAV format to Mp3 (actually, it will convert any non-protected music file type - it's very dynamic). It may take a while to figure out how to do the first one, but it will get easier after that.
First, you have to plug the Thomson in to your computer, double-click "My Computer," and then double-click the icon of the Thomson. There should be a folder called "Voice or "REC". If it doesn't show up, select in the window: Tools --> Folder Options --> View --> select Show Hidden Files and folders. Now the right folder should show up. Then, drag the WAV recording to your desktop (or your "My Music" fodler - whichever works best for you), and the computer should make a copy of the WAV recording onto your computer.
Now open up Media Monkey and it should, after several minutes find all music files on your computer, including the WAV recording. Then right-click the WAV recording, and it should have an option to covnert the file type - convert to mp3, and you're done.
-Tha Mp3 Doctor
Mar 22, 2009 | Thomson Lyra PDP2842U MP3 Player
Olympus VN-480 digtial recorder - can't get my files to play back
if the power is interupted or improperly unplugged from the computer, the files may be corrupted... try to play the files and while playing move them to another folder... this may get your files back... else you will need to clear the recorder by pressing stop and erase at the same time for about 3 seconds.
Jan 19, 2009 | Olympus VN-480 Digital Voice Recorder
Corrupted WAV file will not play or transfer to computer
yes!...
after try, try and try again... i have the solution now!
my english is very bad but i will try write good...
ok... i use one file recover (have many softs this type in internet...) i used this: R-Studio
try this and all will be ok!
good luck for yours!
Abimael - Lgm legrandmenteur@hotmail.com
Dec 22, 2008 | Zoom H4 Handy Recorder
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
How to convert audio in notes to wav?
This was a fun project. Here's how I did it. You'll need to download a freeware audio editor named Audacity. I did this on a Mac, but it's cross-platform, and I'm assuming the menus are the same for Windows. http://audacity.sourceforge.net/ Then. (1) Copy .pwi (Note) file to PC (2) Open Audacity (3) Get the Note audio into Audacity by: Project menu Import as raw data (4) Select all of the audio by clicking below its file name at left of the graphic of the file (5) Click on dropdown menu (arrow next to file name) Set Rate to 11025 Hz (6) Convert to WAV by: File menu Export as wav
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
SanDisk SDMX1 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
