Question about Maytag Washing Machines
Hello have a moffat washer commercial quality 9 cycles there is oil on the bottom tray it runs but no aggitating ..it does spin in the spin cycle
  • 7 Answers
SOURCE: amana commercial washer
set up right for at leat 24 hrs before trying to operate the unit
Posted on Nov 07, 2007
co7196
  • 3433 Answers
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Posted on Jun 15, 2009
co7196
  • 3433 Answers
rachet device under agitator is stripped.
GodBlessU
  • 3513 Answers
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Posted on Aug 11, 2009
SOURCE: GE WASHER WCXR1070A2WW TUB FILL AND DRAINS NO SPIN,AGGITATE
HUMS WONT START
Posted on Jan 19, 2010
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
My Amana washer doesn't aggitate during wash cycle
What is the model number of your unit?
Nov 30, 2012 | Washing Machines
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
AGGITATOR NOT WORKING AND THE SPIN CYCLE NOT WORKING ALSO LOOKING FOR TEARDOWN INSTRUCTIONS.
how old is ure machine if it is about 5 years old and the drum is strugglin to spin u will need your motor brushes changing
Feb 03, 2010 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washing machine will spin on the spin cycle
aggitator? Does it sound like it is? I would put a flat head in the door switch in activiate the cycle "as if it is running" put some weight on the aggitator, see if you can feel it moving while your weight is on it.
Nov 23, 2008 | Maytag Ensignia MAV2757AWW Top Load Washer
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
