Question about Danby DAC8003D Air Conditioner
One year old Danby dac8075ee, HAS NO POWER, what could be wrong ? please help
  • Brian Niten May 11, 2010
    Is this a window unit?
    Novelist:
    Champion:
  • 246 Answers
Your air conditioner has no 'power' on it's own. It must get the power from an electrical outlet.
It is possible that the outlet you are plugged into is 'dead,' i.e. not working. One simple way to test this is to plug in another electrical appliance, hair dryer for example to test it and see if it's working.
If you do this and the other electrical device works then you know your AC is getting the 'power' it needs to operate - in which case you have a problem with your AC, and will probably need to call a Service Tech.
If, however, you plug in another device and it - too - does not work then you know the problem is within the outlet, probably a 'breaker' that is off or has tripped off. So, you need to locate the breaker - box.
This "breaker - box" (in most houses) will be located in the garage, utility room, or behind a door somewhere in the house, i.e. kitchen or bedroom.
If your outlet is not working - just go to the breaker box and open the door and look for a breaker (looks like a light switch) that is in the off position or perhaps half way off and half way on. Once you find this breaker - be sure your AC is plugged in and - just flip it (breaker switch) back in the "on" position.
Note: if the breaker switch trips right back off - then you know you have a direct short in your AC and probably will need the help of a Service Tech.
If this is the problem and the breaker stays in the on position and the AC runs and cools - you are probably ok, unless the breaker trips again in a short time span.
If that happens you most likely have a problem in the unit although it's possible the breaker is bad - in any event you are probably in the need of a Service Tech.
good luck!
Posted on May 08, 2010
My 1 year old Danby DBC514BLS tray in back is overflowing on the floor/hardwood. What could be wrong?
Its probably the defrost tray. Most fridges / freezers allow the defrosted water to run into a pan at the back of the unit where it evaporates away. If there is too much water, the tray cant handle it and it overflows.
Nov 20, 2016 | Danby Refrigerators
Danby ddw496w
Maybe you have the wrong part , contact danby and ask a replacement
Apr 07, 2008 | Danby DDW496W Free-Standing Dishwasher
Where is the fuse in the danby model DAC10010E window air conditioner
more than likely there is no fuse mabey a loose wire or bad switch. I would pull the guts out of the case and check the wiring also a good time to clean the inside of the coil and other hard to reach parts
Nov 21, 2017 | Danby Heating & Cooling
Danby freezer
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Mar 23, 2014 | Freezers
All the lights are on and the dehumidifier isn't working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 06, 2010 | Danby DDR4009EE Dehumidifier
Danby wine cooler is not getting cold. Fan is running and there is power. Please help. Thanks
Last one of these brought to me had lost it's charge. They are not very well built.
If your within 5 years, take it back to where you bought it. Unit's have a 5 year warranty on the compressor. If the compressor is bad, negotiate trade-in for a newer unit as you can buy a new, better unit for about the same amount of money.
Dec 11, 2009 | Danby Refrigerators
Has power but will not come on????
Have you checked the arm? If it is in the up position ... simply push it down. maybe something flipped the interior switch... check that also.
Sep 27, 2009 | Danby DDW1805W Designer Series...
My DANBY DMW744W 700 watts does not work?
What would cause the plastic turn table shaft plate holder in the center to ignite
Feb 22, 2008 | Danby DMW650 700 Watts Microwave Oven
Danby DAC8003D Air Conditioner Logo
207 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
