Question about Woods 59028 Programmable Timer Switch Light Almond
Connect switch and lights flash
Timer is onnected but timer does not perfrom. Lights are contantly blinking
    Guru:
  • 351 Answers
This is the usual reaction of a timer when the line and load are swapped in making the connections . Review your connections and make sure that the power is connected to the line wires . usually black ,, and the light, is connected to the load side wires .. usually red.
Posted on May 06, 2010
Fan stops then operation light flashes rapidly and timer light comes on flashing slowly. Turn off with remote and the lights continue to flash.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jun 22, 2015 | Televison & Video
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
I just installed a Woods Digital In-wall Timer Model #59018. When I switch the power and manually turn the power on, the lights rapidly flash on and off. This is a three-way outlet and I have red, black...
3-way outlet or 3-way switch?
Woods 59018 only replaces single-pole switch, and does not work for 3-way application. Often connecting timer wrong will cause lights to blink. No harm done to lights, timer or wiring.
There are several timers that work with 3-way. In each case the timer replaces 1 switch and other 3-way switch must be rewired.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
http://waterheatertimer.org/ST01C-program.html#3-way
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Aug 03, 2013 | Hardware & Accessories
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 30, 2012 | Hardware & Accessories
I have installed the Utilitech timer switch # 0141224 with all of the wires connected as they are explained in the installation packet. The timer works and turns on the lights, however it only turns on 4...
Utilitec is single-pole timer.
Wiring sounds correct. Lights will blink if timer white white is connected with timer red wire. Lights will not turn ON if timer red and timer black are reversed. Green to ground is not necessary for timer operation.
Check light bulbs are operational.
Bundle of white wires are neutral wires.
Timer white wire requires neutral connection to complete circuit to timer electronics.
If bulbs are good, it is likely that loose white wire is problem, since each of the outdoor lights also needs neutral wire to complete circuit.
Having 6 white wires connected together, plus stranded wire from timer, takes a large wire nut, and that many wires can have a wire fall loose without notice. You can solder wires together, or break the group apart under different wire nuts with a jumper wire between.
Resources:
http://waterheatertimer.org/How-to-twist-electric-wire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 15, 2011 | Intermatic Inc. ST01C Digital In-Wall...
After installing timer, lights flash on and off.
When lights blink, timer is wired wrong.
Error: The white wire is connected with red-or-blue wire instead of connected to neutral.
Timer has 4 wires: green for ground, black for hot, white for neutral, and red-or-blue wire for Load.
Open following link for wiring instructions and illustration:
http://waterheatertimer.org/Programmable.html#wire
Aug 06, 2011 | Leviton 500W - 6512H-W - Alabaster
I have a 7-DAY DIGITAL-IN-WALL TIMER model number #141224. I have tried calling you peopel at least 6 times, staying on the phone for as long as a hour, and I still cant get you. I am having...
A) Open following link to identify timer and download instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
B) This timer is for single pole only and will not work for 3-way switching.
Timer does not have astronomical function.
C) If lights are blinking, timer is wired incorrectly.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
D) If you have trouble with programming, add a comment and say specifically where you are having problem for return comment.
I have programmed and tested this timer. Information above is accurate and tested.
E) Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 14, 2011 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
Heres how to wire timer
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
I have a 59028 timer, and when I turn the lights on they flash - versus staying on.
59028 is a Woods in-wall timer.
See Woods timers and manuals:
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
The lights are blinking so the red and white wires are connected together.
Here's what to do Switch has 2 wires.
1) Green wire connects to bare copper
2) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
Nov 20, 2010 | Hardware & Accessories
1998 Buick Regal GS, Several problems are
start by checking the front wiring harness for corrosion , best is to do a continuity test on all the wires, look for corrosion in connecting harness, time consuming but the only way
Nov 28, 2009 | 1998 Buick Regal
Woods 59028 Programmable Timer Switch Light Almond Logo
237 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
