Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Govener over reves engine for no reason. Tecumseh 8HP Model TVM195 150220F On a Snapper riding mower Model 3080S. Just replaced the carburetor P/N632991. Engine will idle if I push in the govener lever on the engine, but when I let go it pulls the throttle control on the carburetor wide open. I dont know what cause this? I can disconect the govener linkage from the carburetor and install two seperate controls for the choke and the throttle. I dont know if this will hurt the engine running it with the govener disconected from the carburetor?
    Top Expert:
  • Tecumseh Master
  • 26,730 Answers
Sounds to me like the throttle linkage is upside down.
Posted on May 05, 2017
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8 hp problems
I had exactly the same problem, I tried to clean the carb several times without any luck. I gave up on the carb as it was an EPA style without adjustable mixture needles. Bought a new carb for it, installed it and the engine fired up right away. Took me 10min to let it warm up and dial the mixture, it has been fine ever since.
I recommend to buy the replecement carb old-new stock mfg pn: 632334A Tecumseh Carburetor with mixture needles
This place helped me out with one.
Posted on Jan 17, 2009
  • 190 Answers
SOURCE: oil leak tecumseh engine OVRM120-22053F
oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
clean cranksaft with fine sand paper
a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
heres the manual.pdf page 75
Posted on Mar 23, 2009
SOURCE: carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Posted on Mar 26, 2009
  • 32 Answers
SOURCE: Bad governor on 6.5 hp Tecumseh engine?
did you clean the carb yet?
Posted on Jul 20, 2009
  • 153 Answers
SOURCE: gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Posted on Sep 27, 2009
I switched my SR830 mower from the original 8 hp briggs to a 17.5 hp Tecumseh off a later model. I need to know how this engine and starter solenoid wires up
  1. Tecumseh Small Engine Parts - RepairClinic.com
    www.repairclinic.com/Shop-For-Parts/.../Tecumseh-Small-Engine-Parts Huge selection of Tecumseh Small Engine parts in stock. Same day shipping. Open 7 days a week. 365 day return policy.
Jul 20, 2015 | Snapper Garden
Snapper Mower hard to start/run
the choke is controlled by a rod that goes to the muffler it's a open or closed thing see a lot more problems with dirty carbs and the needle valve seats swelling from the fuel
May 28, 2012 | Garden
I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
Sep 25, 2009 | Garden
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
Need a carburetor
http://www.ariens.com/ Hope this helps
Jun 02, 2009 | Garden
Snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Apr 14, 2009 | Garden
Carburetor linkages for riding lawn mower
Mar 24, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
332 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
