Printer will not stop.
My paper is larger then the printed picture , so i assume [hate that word] this is not the problem
  • dupster1 Mar 27, 2008
    not to be a smarty, but give me directions to remove the soft ware from my pc, the rest seems easy if it works,
    Genius:
  • 3,587 Answers
Yes..that's a good assumption..like that word better?
so, remove the software for printer from computer
turn off printer
go here for new driver set
reinstall drivers
run it
Posted on Mar 27, 2008
How do I make the text larger on my office jet 4630 printer
This is the font setting in the application.
Make sure the font is at least 12.
(I am assuming the default settings in the printer setup.)
Oct 25, 2015 | HP Officejet 4630 Inkjet Multifunction...
I requested 3 prints, [color] i had to stop printer manualy, as it would not stop . i activated it again and it resumed making the same pictures,i have deactivated my entire system but to no avail,i just...
hmm..interesting..that usually happens when the image size is larger than the print area the printer handles..check your scaling on your photo application, so that the image is NOT larger than your printable area..
Mar 26, 2008 | Computers & Internet
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Wants to print on 81/2 by 14 instead of 81/2x11
go to fax setting paper size input a4 or input sim 26-6 and chenge nomberto 9 and press start
Oct 17, 2012 | Sharp AR-M207 All-In-One Laser Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam Lexmark E250d
I hate to state the obvious and I am not patronising you, but is the rear door fully closed (did it click into place) - probably. I wonder how many pages the printer has printed? If you are lucky you might be able to print out a demo page (hold the "okay" button down - the large one with the diamond/triangle on it). If it is a high number (say over 10,000 pages) then perhaps the paper pick rollers have stopped working? Also, what paper are you using? Heavy (100gsm or above) or thin (under 75 gsm) may have feed problems.
If this doesn't work you could always try printing to the rear door - this would probably stop the jam hopefully. This would enable you to print a demo page at least so you can see its page output.
Hope this helps you out.
Aug 09, 2008 | Lexmark E250d Laser Printer
Recurrent paper jam
well, i hate to admit this, but we never solved it. for the C762N we had in our shop, we're assuming the frame is tweaked just a bit (the machine i was working on had some damaged lower plastics, probably from a small 1 foot drop or so).
best of luck.
chris
Apr 03, 2008 | Lexmark C762 Laser Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
