Question about GE DCD330EB Electric Dryer
Jammed coin slide - GE DCD330EB Electric Dryer
  • 10,865 Answers
Hello. Get a can of a penetrating lubricant called WD-40. Spray the top side and the bottom side of the coin slide and use a pair of pliers to gently pull the slide in and out. If it won't move spray it again and let it sit for an hour while the penetrating lubricant does it's job. Joe
Posted on May 05, 2010
Coins fall directly into change opening on front instead of dropping into collection box
Your coin-mech is jammed and the coins are bypassing the collection box. use the service door key and visually inspect the coin mechanism for a blockage
Apr 22, 2016 | Washing Machines
I have a Mercato 2000 Snack Vending with Summit 300 Satellite Drink Machine. The coins do not deposit into the dispensers. It collects at the top. How do i get it to drop into the dispensers?
you may have a coin jammed in the coin reader device. I know absolutely nothing about your machine but am a gaming attendent and have the same type of fault occuring on gaming machines from time to time. Foreign coins or bent coins also can jam up the reader.
check if the coin reader can open up to release coins.
Jun 17, 2015 | Retail Supplies
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
It wont pay out money on easy streak fruit machine.
check that your hopper (the part where all the £1 coins pay out) isnt jammed up with coins, try and move the hopper around clockwise with your hand and see if it is jammed up
Nov 16, 2010 | Kitchen Ranges
How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Oct 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Oct 28, 2008 | Maytag Washing Machines
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
GE DCD330EB Electric Dryer Logo
192 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
