Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Weedeater starts and immediately shuts off. I checked the fuel filter and replaced the plug the unit is 1 year old.
    Sniper:
  • 53 Answers
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
Posted on May 06, 2010
The fb 25 weedeater has fired off a time or 2 one time it started but died like 2 seconds and only fired one more time with25 pulles
Put a little in the cylinder via the spark plug hole and see it will run a second or two. If it does then your carburetor needs repairs or replacing.
Most shops will not even accept these cheap unit in for repairs.
Mar 14, 2015 | Weedeater Garden
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
My featherlite FL26 weedeater stalls immediately after starting.
I would start by emptying out all the old fuel,then pull the recoil several times to clear the carburetor. Then add fresh oil/gas mix,should be 40:1 which is 3.2oz of two cycle oil to one gallon of gas. Also check the fuel line and primer line for good connection to the carb. and make sure the spark plug is good.
Jan 12, 2011 | Garden
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Garden
Mower starts then shuts off
hey mate, it sounds like you have a fuel blockage weather it is in the fuel tank fuel filter or carby you cant tell, i recommend that you start at the fuel tank and flush it out make sure there is no debris on the filter screen then check for a in-line fuel filter you can remove this and back flush it with compressed air or replace with a new one, if it still does not work then you have a blockage in your carby, this is a bit more complex alot or small parts in there and i would recommend taking it to your local small engine dealership for repair...
Regards
Brad:)
Sep 21, 2009 | Garden
Truck turns over but wont start
check for spark, check for fuel, check fuses and relays, replace old oil,old fuel
Sep 20, 2009 | 1997 Chevrolet S-10 Pickup
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
910 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
