Question about Epson PictureMate 500 InkJet Photo Printer
Looking for screws to take it apart - Epson PictureMate 500 InkJet Photo Printer
  • 26 Answers
Try to look under panels that may have been placed on using adhesive, also sometimes companies will save money by putting together parts like jigsaw puzzle using tabs that link to each other so be mindful of that. One of my previous printers was like this and it may be like that for you. so take a screw driver and lightly pryapart at the cracks a bit or find panels you may have to pull of before you find more screws!
Posted on May 05, 2010
How do you take this body apart to get to the to the motormotor
Look for recessed screws from the bottom and in the bag area. Take all the screws out and pull top and borrow apart. Keep track of the screws. Some may be longer than others.
Jan 29, 2015 | Black and Decker USA Black & Decker...
Plastic got in shredder won't work,would like instruchions to take it apart to fix
Take out the paper bin. Look for and remove any screws holding the top part of the shredder to the base. Take the top off, turn it upside-down and you might be able to remove the jam. To take the top apart, remove all of the screws that are under or near the edge. Look out, it gets very messy when you take it apart!
Fellowes sells replacement gears for some of their shredders.
Mar 30, 2014 | Fellowes Manufacturing Powershred SB-97CS...
I can not open my "key fob" to replace the battery, does anyone know how to open it?
hey,, There are hidden clips inside you just need to pry it apart... some of them the back cover slides off, but most just pry apart. Look at the back and make sure there are no screws and no hidden screws (like those under rubber stoppers, the stoppers must be removed to expose them).. any way once thats verified, simply insert a flat head (blade) screw driver in between the seems and pry it apart.
Dec 28, 2012 | Cars & Trucks
My kenmore washer leaks,and i wanna know how to take apart to see where it leaks
Look for screws under the top edge of top. Pry gently looking for the spring clips so the top will raise up or the front panel will come off. Also look for screws at the bottom. It depends on your model.
Mar 01, 2012 | Kenmore Washing Machines
My dualit hand mixer has become noisy as if something is loose inside. Can I take it apart to have a look.
There is 2 screws if you look at the bottom, where the cable is wind. you can see
them through the winding wheel. I had a completly dead machine, by removing these screws i could replace the cable and my machine works again :-)
Jul 03, 2010 | Dualit 88407 300 Watts Hand Mixer
Taking apart Samsung Propel A767
Most cell phones also have little plastic tabs holding them inside besides the screws,i have found that if you look closely ,you'll see some sort of a little slot or opening that you can slide a thin small flat tip screw driver in, Carefully work the screw driver around and the plastic tabs will open.
May 15, 2010 | Cell Phones
Cant seperate pump motor from jets tring to clean jets
Every thing is made to come apart, look for any screws , if no screws then it doesnt come apart.
Feb 03, 2010 | Flotec Corrosion Resistant Shallow Well...
I am trying to dismantle my hp kb-0316 keyboard. i took all the screws out of the back but it's stuck in the corners when i try to take it apart. is there someway to take it apart?
i believe that some of the screws are not taken out... try to look at the back in the middle of the keyboard some of the screws are covered by the stickers look on it remove the sticker..
Jun 23, 2009 | Computers & Internet
I have removed all the screws from my Evesham W730-K8 laptop because i need to get to the power socket inside, but the laptop still won't come apart. What am I missing?
The best rule to remember is do not force it apart if it does not come apart easy then look for a hidden screw the case does have snap locks on the sides try starting at a point that you can get your fingernail into and slowly move the part that is not coming apart apply a little force but make sure that all screws have been removed you may have to remove some of the thin plastic covers and the battery to make sure all of the screws have been removed
Jun 06, 2009 | Computers & Internet
Kitchenaide mixer model KHM3WH-1
You can see the parts breakdown HERE. It looks like there are 3 screws on the bottom...
Aug 09, 2008 | Food Mixers
Epson PictureMate 500 InkJet Photo Printer Logo
298 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
