Question about Ovens
My ST 92 Salva Oven displays fault code AL 3 what does it mean
My ST 92 Salva Oven displays the following fault or error code: - AL 3 What does it mean
My salva st-92 oven is displaying AL9 fault code
Posted on Jan 02, 2015
  • 320 Answers
SOURCE: Zanussi double oven switches off during cooking.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Posted on Dec 02, 2010
SOURCE: fault code F5
what does f7 means
Posted on Apr 11, 2008
  • 417 Answers
SOURCE: Our GE double oven is 17 years old and I suddenly
F1 usually means that electronic control clock is faulty, the remedy is to replace it .
Posted on Dec 13, 2010
Testimonial: "Yes, I have called an appliance shop and they can replace the sessor control"
SOURCE: Whirpool GBD307 - Display not working
replace the 22uf-50volt capacitor. Looking at the glass display bottom right corner you need to flip the board to the tan side in that same spot you will see two small caps. You want to replace the smaller one. I replaced both for $2.00. Radio shack has them in stock.
Posted on Jul 17, 2011
mc1bean
  • 3053 Answers
SOURCE: f1 error code displays and oven beeps. Oven seems
Hello, mk
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Error f19
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
May 04, 2014 | LG LWD3081ST Electric Double Oven
Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | GE Ovens
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
My oven is giving me an error of E6 F2, what does that mean
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
531 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
